I want to upload some pictures to show my problem, but I don't have enough points. Therefore, I can only explain it with my poor English. Sorry. I am using a turtlebot2 to do my experiments. It worked well for a long time. But this Monday, after I built a new map or maybe after I decrease the max_vel_x, I found it can not locate itself well any more. I usually start my turtlebot2 at the same position as the position that I start to gmapping. At first, the local_map can match the static map well. But if I send a goal that is a long-distance away, the local_map would drift. Then the local_map can not match the static map well with not only distance but also orientation. I have tried everthing I can think out to fix it, but none of them worked. Need help~~
The map is a big rectangle, about 6m*6m. I can upload now. image description image description
Originally posted by LucYang on ROS Answers with karma: 56 on 2018-03-26
Comment by ahendrix on 2018-03-26:
It looks like your sensor can't see the walls all the way around. Have you recently increased the size of your map?
Comment by LucYang on 2018-03-26:
No,the map is the same as it was at last week and it worked well. This problem appeared just yesterday.
Comment by jayess on 2018-03-26:
Can you repost the images as screenshots instead of pictures taken with a phone/camera?
Comment by pengjiawei on 2018-03-28:
what if you set the goal near your turtlebot?
image description I did this and the turtlebot2 behaved better, but still not good enough.
Originally posted by LucYang with karma: 56 on 2018-03-28
Comment by jayess on 2018-07-28:
Please don't use an answer to provide more information about your question. This isn't a forum. Please update your question with this information instead.
