It is so strange that I use link text, the fake node works. However, when I use Matlab Ros toolbox, and input some command like "rosinit", the tutorial doesn't work. It shows that image description
roslaunch turtlebot3_fake turtlebot3_fake.launch
... logging to /home/ise-admin/.ros/log/292cbdaa-2ea7-11e8-9362-509a4c311940/roslaunch-ise-linux-1-5245.log
Press Ctrl-C to interrupt
xacro: Traditional processing is deprecated. Switch to --inorder processing!
To check for compatibility of your document, use option --check-order.
For more infos, see http://wiki.ros.org/xacro#Processing_Order
No such file or directory: /home/ise-admin/catkin_ws/src/turtlebot3/turtlebot3_description/urdf/turtlebot3_.urdf.xacro
XacroException('No such file or directory: /home/ise-admin/catkin_ws/src/turtlebot3/turtlebot3_description/urdf/turtlebot3_.urdf.xacro',)
while processing /home/ise-admin/catkin_ws/src/turtlebot3/turtlebot3_bringup/launch/includes/description.launch.xml:
Invalid <param> tag: Cannot load command parameter [robot_description]: command [/opt/ros/kinetic/lib/xacro/xacro '/home/ise-admin/catkin_ws/src/turtlebot3/turtlebot3_description/urdf/turtlebot3_.urdf.xacro'] returned with code [2].
Param xml is <param command="$(arg urdf_file)" name="robot_description"/>
The traceback for the exception was written to the log file
I have tried to check the turtlebot3_fake.launch, but it is same to github. I also tried rename a .xarco file as turtlebot3_.urdf.xacro, I copied the code from \ turtlebot3_burger.urdf.xacro to turtlebot3_.urdf.xacro. However, error occurs.image description
I want to know why the tutorial does work.Is there any relationship between the "strike" and "Matlab Ros toolbox"?
Thank you!
Originally posted by Pujie on ROS Answers with karma: 106 on 2018-03-23
Post score: -1
Comment by Pujie on 2018-03-23:
link text
Comment by jayess on 2018-03-23:
Please don't use an image to display text. Images are not searchable and people cannot copy and paste the text from the image. Please update your question with a copy and paste of the text using the preformatted text (101010) button instead of using an image.
http://wiki.ros.org/Support
Ok, I have added text for first picture, as for the second one, I just want to show that my method was not available.
Hello :)
You have to set which TurtleBot3 you want.
$ export TURTLEBOT3_MODEL = burger
or
$ export TURTLEBOT3_MODEL = waffle_pi
and
$ roslaunch turtlebot3_fake turtlebot3_fake.launch
Originally posted by Darby Lim with karma: 811 on 2018-03-23
Yes, this is parts of the problem. I solved it today. In recent days turtlebot3 has updated their code on github. So I update the code by git pull and export the variable(maybe change them in bashrc is good too) export TURTLEBOT3_MODEL=burger export TB3_MODEL=burger Thank you for help.
It should be
$ export TURTLEBOT3_MODEL=burger
or
$ export TURTLEBOT3_MODEL=waffle_pi
and then
NOTE: the = sign shouldn't have space between words
Originally posted by AustinJia with karma: 31 on 2018-07-21
Comment by NEngelhard on 2018-07-22:
Minor details like that should be rather posted as a comment on the first answer and not posted as a separate answer.
