Hello,
I have robot_localization setup to fuse IMU data from a flight controller with pose data from ORB-SLAM. I am also using gmapping to generate a 2D map. When I run my robot_localization node, my tf tree becomes odom -> base_link -> camera_link, which I think is what I'm supposed to get because right now I'm assuming that my camera is my base. However, I'm also trying to incorporate a particle filter into this setup. And when I try to run my particle filter, my tf tree changes to map -> base_link and I'm not sure why. I've been trying to find answers but I feel like a lot is going over my head.
In any case, here are the steps I did when I was using robot_localization and also use the particle filter:
  1. Go to a known fixed position (initial point).
  2. Run camera, ORB, robot_localization node, and gmapping. (At this point, my tf tree is odom -> base_link)
  3. Start mapping around and return to initial point when done.
  4. Save the map using map_server.
  5. Close gmapping.
  6. Launch the particle filter and range finders. (This is where my tf tree changes to map -> base_link while my odom frame seems to just float and is unconnected to anything).
Also here is the config file I use for my robot_localization node:
frequency: 50
sensor_timeout: 0.1
two_d_mode: true
transform_time_offset: 0.0
transform_timeout: 0.0
print_diagnostics: true
debug: false
publish_tf: true
publish_acceleration: false
map_frame: map              # Defaults to "map" if unspecified
odom_frame: odom            # Defaults to "odom" if unspecified
base_link_frame: base_link  # Defaults to "base_link" if unspecified
world_frame: odom           # Defaults to the value of odom_frame if unspecified
pose0: /orb/pose
pose0_config: [true,  true,  true,      # Position
               true,  true,  true,    # Orientation
               false,  false, false,     # Linear Velocity
               false,  false, false,      # Angular Velocity
               false,  false, false]     # Linear Acceleration
pose0_queue_size: 2
pose0_nodelay: false
pose0_differential: false
pose0_relative: false
imu0: /mavros/imu/data
imu0_config: [true, true, true,    # Position
              true, true, true,     # Angular Velocity
              true, true, true]     # Linear Acceleration
imu0_nodelay: false
imu0_differential: true
imu0_relative: false
imu0_queue_size: 5
imu0_pose_rejection_threshold: 0.8                 # Note the difference in parameter names
imu0_twist_rejection_threshold: 0.8                #
imu0_linear_acceleration_rejection_threshold: 0.8  #
imu0_remove_gravitational_acceleration: false
use_control: true
stamped_control: false
control_timeout: 0.2
control_config: [true, false, false, false, false, true]
acceleration_limits: [1.3, 1.0, 0.0, 0.0, 0.0, 3.4]
deceleration_limits: [1.3, 1.0, 0.0, 0.0, 0.0, 4.5]
acceleration_gains: [0.8, 0.5, 0.0, 0.0, 0.0, 1.5]
deceleration_gains: [1.0, 0.7, 0.0, 0.0, 0.0, 1.0]
process_noise_covariance: [0.05, 0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0.05, 0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0.06, 0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0.03, 0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0.03, 0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0.06, 0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0.025, 0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0.025, 0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0.04, 0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0.01, 0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0.01, 0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0.02, 0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0.01, 0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0.01, 0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0.015]
initial_estimate_covariance: [1e-6, 0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    1e-6, 0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    1e-9, 0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    1e-9, 0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    1e-9, 0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    1e-9, 0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    1e-9, 0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    1e-9, 0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    1e-9, 0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    1e-5,  0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     1e-5,  0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     1e-9,  0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     1e-6, 0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    1e-6, 0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    1e-9]
EDIT: Robot setup specifics based on tuandl's comments
Our robot setup is as follows:
  • We are using the r200 realsense camera to extract depth data and turn it into laserscan using the depth_to_laserscan node
  • With this, we are using the ORB-SLAM package to get pose data and combine it with our flight controller IMU data
  • We use the robot_localization package to fuse the ORB-SLAM pose with the flight controller IMU and our config file is what I have above. This resulting odom data is our odom->base transform
  • Next we run gmapping to construct our 2d map and save it using map_server
  • We then load this map into our custom BFL particle filter as well as range data from 3 range sensors attached to our robot. The resulting pose is our map->base transform.
Right now we are having trouble creating our map->odom transform in our particle filter, and we are trying to find some reference code such as the amcl code.
EDIT2: Here is the code we currently have for our custom particle filter. Most of this is taken directly from the BFL tutorial on how to write a custom filter. The parts that we added relate to gathering the data from our EKF and range finders:
#include <filter/bootstrapfilter.h>
#include <model/systemmodel.h>
#include <model/measurementmodel.h>
#include "nonlinearSystemPdf.h"
#include "nonlinearMeasurementPdf.h"
#include <iostream>
#include <fstream>
// Include file with properties
#include "constants.h"
#include "customparticlefilter.h"
#include <ros/ros.h>
#include <string>
#include <std_msgs/Empty.h>
//Need messages types for linear velocities and range measures
#include <ardrone_autonomy/Navdata.h>
//#include <ardrone_autonomy/Ranges.h>
#include <nav_msgs/Odometry.h>
#include <geometry_msgs/Vector3.h>
#include <geometry_msgs/PoseArray.h>
#include <geometry_msgs/PoseStamped.h>
#include "nav_msgs/GetMap.h"
#include "map/map.h"
#include <tf/transform_broadcaster.h>
#include <tf/transform_listener.h>
#include "tf/tf.h"
using namespace MatrixWrapper;
using namespace BFL;
using namespace std;
 The necessary SYSTEM MODEL is:
 x_k      = x_{k-1} + v_{k-1} * cos(theta) * delta_t
 y_k      = y_{k-1} + v_{k-1} * sin(theta) * delta_t
class ParticleFilterNode
   ros::NodeHandle nh_;
   ros::Subscriber navi_sub;
   ros::Subscriber sensor_sub;
   ros::Publisher pose_pub;
   ros::Publisher particle_pub;
   map_t* map_;
   NonlinearSystemPdf *sys_pdf;
   SystemModel<ColumnVector> *sys_model;
   NonlinearMeasurementPdf *meas_pdf;
   MeasurementModel<ColumnVector,ColumnVector> *meas_model;
   MCPdf<ColumnVector> *prior_discr;
   CustomParticleFilter *filter;
   ros::Time prevNavDataTime;
   double dt;
   tf::TransformBroadcaster br;
   tf::TransformBroadcaster* tfb_;
   tf::TransformListener tf_listener;
   tf::Transform transform;
   tf::StampedTransform odom_to_base_link;
   tf::StampedTransform map_to_base_link;
   tf::Transform latest_tf_;
   struct TransformListenerWrapper : public tf::TransformListener
      inline tf2_ros::Buffer &getBuffer() {return tf2_buffer_;}
   TransformListenerWrapper* tf_;
   ros::Duration transform_tolerance_;
public:
   ParticleFilterNode()
       navi_sub = nh_.subscribe("/odometry/filtered", 1, &ParticleFilterNode::InputCb, this);
       sensor_sub = nh_.subscribe("/lidarArray", 1, &ParticleFilterNode::MeasurementCb, this);
       pose_pub = nh_.advertise<geometry_msgs::PoseStamped>("/pose_pf",1);
       particle_pub = nh_.advertise<geometry_msgs::PoseArray>("/particlecloud",1);
       dt = 0.0;
       sys_model = NULL;
       meas_model = NULL;
       filter = NULL;
       map_ = NULL;
       requestMap();
   ~ParticleFilterNode()
       delete sys_model;
       delete meas_model;
       delete filter;
   void CreateParticleFilter()
        * NonLinear system model      *
       // create gaussian
       ColumnVector sys_noise_Mu(STATE_SIZE);
       sys_noise_Mu(1) = MU_SYSTEM_NOISE_X;
       sys_noise_Mu(2) = MU_SYSTEM_NOISE_Y;
       sys_noise_Mu(3) = MU_SYSTEM_NOISE_THETA;
       SymmetricMatrix sys_noise_Cov(STATE_SIZE);
       sys_noise_Cov = 0.0;
       sys_noise_Cov(1,1) = SIGMA_SYSTEM_NOISE_X;
       sys_noise_Cov(1,2) = 0.0;
       sys_noise_Cov(1,3) = 0.0;
       sys_noise_Cov(2,1) = 0.0;
       sys_noise_Cov(2,2) = SIGMA_SYSTEM_NOISE_Y;
       sys_noise_Cov(2,3) = 0.0;
       sys_noise_Cov(3,1) = 0.0;
       sys_noise_Cov(3,2) = 0.0;
       sys_noise_Cov(3,3) = SIGMA_SYSTEM_NOISE_THETA;
       Gaussian system_Uncertainty(sys_noise_Mu, sys_noise_Cov);
       // create the nonlinear system model
       sys_pdf = new NonlinearSystemPdf(system_Uncertainty);
       sys_model = new SystemModel<ColumnVector> (sys_pdf);
        * NonLinear Measurement model   *
       // Construct the measurement noise (a scalar in this case)
       ColumnVector meas_noise_Mu(MEAS_SIZE);
       meas_noise_Mu(1) = MU_MEAS_NOISE;
       meas_noise_Mu(2) = MU_MEAS_NOISE;
       meas_noise_Mu(3) = MU_MEAS_NOISE;
       SymmetricMatrix meas_noise_Cov(MEAS_SIZE);
       meas_noise_Cov(1,1) = SIGMA_MEAS_NOISE;
       meas_noise_Cov(1,2) = 0.0;
       meas_noise_Cov(1,3) = 0.0;
       meas_noise_Cov(2,1) = 0.0;
       meas_noise_Cov(2,2) = SIGMA_MEAS_NOISE;
       meas_noise_Cov(2,3) = 0.0;
       meas_noise_Cov(3,1) = 0.0;
       meas_noise_Cov(3,2) = 0.0;
       meas_noise_Cov(3,3) = SIGMA_MEAS_NOISE;
       Gaussian measurement_Uncertainty(meas_noise_Mu, meas_noise_Cov);
       meas_pdf = new NonlinearMeasurementPdf(measurement_Uncertainty, map_);
       meas_model = new MeasurementModel<ColumnVector,ColumnVector>(meas_pdf);
        * Linear prior DENSITY     *
       // Continuous Gaussian prior (for Kalman filters)
       ColumnVector prior_Mu(STATE_SIZE);
       prior_Mu(1) = PRIOR_MU_X;
       prior_Mu(2) = PRIOR_MU_Y;
       prior_Mu(3) = PRIOR_MU_THETA;
       SymmetricMatrix prior_Cov(STATE_SIZE);
       prior_Cov(1,1) = PRIOR_COV_X;
       prior_Cov(1,2) = 0.0;
       prior_Cov(1,3) = 0.0;
       prior_Cov(2,1) = 0.0;
       prior_Cov(2,2) = PRIOR_COV_Y;
       prior_Cov(2,3) = 0.0;
       prior_Cov(3,1) = 0.0;
       prior_Cov(3,2) = 0.0;
       prior_Cov(3,3) = PRIOR_COV_THETA;
       Gaussian prior_cont(prior_Mu,prior_Cov);
       // Discrete prior for Particle filter (using the continuous Gaussian prior)
       vector<Sample<ColumnVector> > prior_samples(NUM_SAMPLES);
       prior_discr = new MCPdf<ColumnVector>(NUM_SAMPLES,STATE_SIZE);
       prior_cont.SampleFrom(prior_samples,NUM_SAMPLES,CHOLESKY,NULL);
       prior_discr->ListOfSamplesSet(prior_samples);
        * Construction of the Filter *
       filter = new CustomParticleFilter (prior_discr, 0.5, NUM_SAMPLES/4.0);
   // Need to create a Ranges message
   void MeasurementCb(geometry_msgs::Vector3 sensor)
       ColumnVector measurement(3);
       measurement(1) = sensor.x / 100;
       measurement(2) = sensor.y / 100;
       measurement(3) = sensor.z / 100;
       //ROS_INFO("Measurement: %f",measurement(1));
       filter->Update(meas_model, measurement);
       PublishParticles();
       PublishPose();
   // Need to create a velocities message type
   void InputCb(nav_msgs::Odometry msg)
       if(!prevNavDataTime.isZero()) dt = (msg.header.stamp - prevNavDataTime).toSec();
       prevNavDataTime = msg.header.stamp;
       ColumnVector input(2);
       //Since msg comes from Odometry, need to go down the branches to get linear vel
       input(1) = msg.twist.twist.linear.x*dt*0.001;
       input(2) = msg.twist.twist.linear.y*dt*0.001;
       filter->Update(sys_model,input);
   void PublishParticles()
       geometry_msgs::PoseArray particles_msg;
       particles_msg.header.stamp = ros::Time::now();
       particles_msg.header.frame_id = "/map";
       vector<WeightedSample<ColumnVector> >::iterator sample_it;
       vector<WeightedSample<ColumnVector> > samples;
       samples = filter->getNewSamples();
       for(sample_it = samples.begin(); sample_it<samples.end(); sample_it++)
           geometry_msgs::Pose pose;
           ColumnVector sample = (*sample_it).ValueGet();
           pose.position.x = sample(1);
           pose.position.y = sample(2);
           pose.orientation.z = sample(3);
           particles_msg.poses.insert(particles_msg.poses.begin(), pose);
       particle_pub.publish(particles_msg);
   void PublishPose()
       Pdf<ColumnVector> * posterior = filter->PostGet();
       ColumnVector pose = posterior->ExpectedValueGet();
       SymmetricMatrix pose_cov = posterior->CovarianceGet();
       geometry_msgs::PoseStamped pose_msg;
       pose_msg.header.stamp = ros::Time::now();
       pose_msg.header.frame_id = "/map";
       pose_msg.pose.position.x = pose(1);
       pose_msg.pose.position.y = pose(2);
       pose_msg.pose.orientation.z = pose(3);
       pose_pub.publish(pose_msg);
       tf::Stamped<tf::Pose> map_to_base;
       /*tf_listener.lookupTransform ( "odom", "/base_link", ros::Time ( 0 ), odom_to_base_link );
       map_to_base_link.setOrigin( tf::Vector3(pose_msg.pose.position.x, pose_msg.pose.position.y, pose_msg.pose.position.z) );
       map_to_base_link.setRotation (pose_msg.pose.orientation);
       tf::Stamped<tf::Pose> odom_to_map;
       try
          tf::Transform tmp_tf (tf::createQuaternionFromYaw(pose(3)),
                                tf::Vector3(pose(1),
                                pose(2),
                                0.0));
          tf::Stamped<tf::Pose> tmp_tf_stamped (tmp_tf.inverse(), pose_msg.header.stamp, "base_link");
          tf_->transformPose("odom", tmp_tf_stamped, odom_to_map);
       catch(tf::TransformException)
          ROS_DEBUG("Failed to subtract base to odom transform");
          return;
       latest_tf_ = tf::Transform(tf::Quaternion(odom_to_map.getRotation()),
                                  tf::Point(odom_to_map.getOrigin()));
       transform_tolerance_.fromSec(0.1);
       ros::Time transform_expiration = (ros::Time::now() +
                                         transform_tolerance_);
       tf::StampedTransform tmp_tf_stamped(latest_tf_.inverse(),
                                            transform_expiration,
                                            "map", "odom");
       this->tfb_->sendTransform(tmp_tf_stamped);
       //br.sendTransform(tf::StampedTransform(map_to_base_link, ros::Time ( 0 ), "map", "base_link"));
       tf_listener.transformPose("map",
                                  pose_msg,
                                  map_to_base);
       latest_tf_ = tf::Transform(tf::Quaternion(map_to_base.getRotation()),
                                  tf::Point(map_to_base.getOrigin()));
   void requestMap()
     // get map via RPC
     nav_msgs::GetMap::Request  req;
     nav_msgs::GetMap::Response resp;
     ROS_INFO("Requesting the map...");
     while(!ros::service::call("static_map", req, resp))
       ROS_WARN("Request for map failed; trying again...");
       ros::Duration d(0.5);
       d.sleep();
     handleMapMessage( resp.map );
   void handleMapMessage(const nav_msgs::OccupancyGrid& msg)
     ROS_INFO("Received a %d X %d map @ %.3f m/pix  Origin X %.3f Y %.3f\n",
              msg.info.width,
              msg.info.height,
              msg.info.resolution,
              msg.info.origin.position.x,
              msg.info.origin.position.y);
     freeMapDependentMemory();
     map_ = convertMap(msg);
     CreateParticleFilter();
   void freeMapDependentMemory()
     if( map_ != NULL ) {
       map_free( map_ );
       map_ = NULL;
     if (sys_model)
       delete sys_model;
     if (meas_model)
       delete meas_model;
     if (filter)
       delete filter;
    * Convert an OccupancyGrid map message into the internal
    * representation.  This allocates a map_t and returns it.
   map_t* convertMap( const nav_msgs::OccupancyGrid& map_msg )
     map_t* map = map_alloc();
     ROS_ASSERT(map);
     map->size_x = map_msg.info.width;
     map->size_y = map_msg.info.height;
     map->scale = map_msg.info.resolution;
     map->origin_x = map_msg.info.origin.position.x + (map->size_x / 2) * map->scale;
     map->origin_y = map_msg.info.origin.position.y + (map->size_y / 2) * map->scale;
     ROS_INFO(" Size X=%d Y=%d Scale=%f Origin X=%f Y=%f", map->size_x, map->size_y, map->scale, map->origin_x, map->origin_y);
     // Convert to player format
     map->cells = (map_cell_t*)malloc(sizeof(map_cell_t)*map->size_x*map->size_y);
     ROS_ASSERT(map->cells);
     for(int i=0;i<map->size_x * map->size_y;i++)
       if(map_msg.data[i] == 0)
         map->cells[i].occ_state = -1;
       else if(map_msg.data[i] == 100)
         map->cells[i].occ_state = +1;
       else
         map->cells[i].occ_state = 0;
     return map;
int main(int argc, char** argv)
   ros::init(argc, argv, "ParticleFilterNode");
   ParticleFilterNode pfNode;
   ros::spin();
   return 0;
Originally posted by trixr4kdz on ROS Answers with karma: 45 on 2018-03-21
My guess is that you are using AMCL pkg for your particle filtered localization?
EDIT1 to answer your comments
it seems like a lot is happening just to get the map->odom transform
This is correct. According to AMCL wiki: "During operation amcl estimates the transformation of the base frame (~base_frame_id) in respect to the global frame (~global_frame_id) but it only publishes the transform between the global frame and the odometry frame (~odom_frame_id).". This means amcl will correct the pose of base_link by adjusting map->odom transform. I took a closer look at AMCL and figured that my previous answer was wrong. I edited it. So back to your original question, could you edit your question by specifying you robot's setup?
is the map->odom->base transform something we can just use the tf robot_state_publisher package for
Maybe you are talking about robot_pose_ekf ?
EDIT2 answer to your new comments
@trixr4kdz sorry for the late reply, I have been caught up with my project for the last couple days.
a way we can also get the map->odom without having to do the same thing amcl is doing
Certainly, you could, but if you ask whether there is an available package then I don't know. IMO, there are 2 options:
  1. consider open source your custom particle filer so everybody can have a look at what is going on. Without knowing what you are doing (for example: why your customer particle filter publishes map->base_link), it's really hard to help.
  2. re-implement the part of AMCL that publish map->odom (from #L1351 to #L1418). This shouldn't be too hard (I know it is NOT easy) since you must have the whole transform: map->odom->base_link->laser_scan from you particle filter.
Originally posted by tuandl with karma: 358 on 2018-03-22
Comment by trixr4kdz on 2018-03-22:
Sorry, I forgot to add that little detail. The particle filter we are using is based of this tutorial from the BFL package
So just to confirm, you are saying that the problem isn't with our use of the robot_localization package but with the particle filter not being a map->odom transform, correct?
Comment by tuandl on 2018-03-22:
Correct. I am not familiar with BFL but a quick look at #L242 make me think...
...BFL works in a similar manner of AMCL.
I see. Thank you very much for the help!
I was looking at the amcl code on github and it seems like a lot is happening just to get the map->odom transform. For our particular case, is the map->odom->base transform something we can just use the tf robot_state_publisher package for?
Comment by trixr4kdz on 2018-03-23:
I edited my original post to add more details about our robot setup. Also apologies for the confusion, we are already using robot_localization to publish our odom->base transform, and I meant to ask if there's a way we can also get the map->odom without having to do the same thing amcl is doing.
Comment by trixr4kdz on 2018-03-26:
I added our particle filter code at the very bottom, but I also put it here, which might be better for you to see: https://repl.it/@trixr4kdz/ParticleFilterNodecpp. Lines 261-299 are our implementation of the AMCL code.
Comment by tuandl on 2018-03-27:
@trixr4kdz I will look at it and get back as soon as possible.
