When I've completed all steps according to the instruction of ROS2 installation, I typed
ros2
and next
ros2 run demo_nodes_cpp talker
into cmd, but got the same reply:
failed to create process.
I wonder what was happening. I'm beginner of ROS2 and appreciate for your help, THANKS!
Originally posted by Sued-Wind on ROS Answers with karma: 11 on 2018-03-19
Comment by gvdhoorn on 2018-03-19:
As always: please include what OS this is and which CPU architecture this is (I know you link a Windows tutorial, but please be explicit). Which RMW are you targeting?
Also: is that all of the error message? Are there additional lines?
Comment by mcevoyandy on 2018-07-03:
Windows 10 Home 1803, VS 2017, Skipped OpenCV and Additional DDS implementations, and used ros2-bouncy-windows-AMD64.zip. The only suggestions I've found relate to having a space in the Python path, but mine is C:\Python37. Txt dump with echo off commented out.
Comment by mcevoyandy on 2018-07-08:
For me, choco installed Python 3.7 and ros2 expects 3.6, I downgraded, but got new errors...
Since it appears you're using Python 3.7 (from the comments), you'll need to build ROS 2 from source until we produce a new set of binaries that work with Python 3.7:
https://github.com/ros2/ros2/wiki/Windows-Development-Setup
Sorry the binaries are not working for you in the meantime. If you'd like to follow up with the issues you're getting with the older version of Python (3.6), please ask a new question.
As a workaround you might be able to avoid any of the programs that need Python, depending on what you want to do, for instance, you can simply run executables directly, e.g.:
 > C:\path\to\ros2\lib\demo_nodes_cpp\talker
Originally posted by William with karma: 17335 on 2018-07-08
Comment by KrzysztofDabek on 2018-08-25:
I installed python 3.6.0 and the problem persists. The path is correct, yet I still get the "failed to create process" error. Is there another python release I have to install?
