ROS2 has been around for a while. I would like to know which distribution is actually using ROS2? I looked at the Lunar distribution website and did not see the specification about its ROS kernel.
Originally posted by Zhoulai Fu on ROS Answers with karma: 186 on 2018-03-17
ROS 2 is (at the moment) a completely separate project, and ROS 1 releases do not share anything (roughly) with ROS 2.
Currently supported ROS 1 releases are Indigo, Kinetic, Lunar and Melodic (see REP 3 and wiki/Distributions).
The only currently supported ROS 2 release is Ardent (see ros2/ros2 - All Releases and ros2/ros2 - Roadmap).
So to answer your questions:
That would be only Ardent at the moment, and the Summer 2018 release in the near future.
I looked at the Lunar distribution website and do not see the specification of its ROS kernel.
Anything currently listed on wiki.ros.org is ROS 1 specific. So none of the currently supported ROS 1 releases use anything from ROS 2.
Edit:
I thought that ROS 1 or 2 to each distribution is like Linux kernel to its distributions.
No, that is not how things are designed. While it would be nice, that is currently not possible.
I would say that a tagged set of the whole of ROS 1 or ROS 2 are the distributions. I don't believe an analogy with the Linux kernel and the various Linux distributions can be made.
Maybe should I say Ros core?
That would be ambiguous, as ros_core is the name of one of the ROS 1 variants or metapackages defined in/by REP 142 (specifically: Specification - Metapackages - ROS Core).
Originally posted by gvdhoorn with karma: 86574 on 2018-03-17
Comment by gvdhoorn on 2018-03-17:\
ROS kernel
I don't believe there is such a thing as the "ROS kernel". Or at least not in the traditional sense of the word kernel ,when used in an operating systems context.
Comment by Zhoulai Fu on 2018-03-17:
I thought that ROS 1 or 2 to each distribution is like Linux kernel to its distributions. Maybe should I say Ros core?
