Hi all ,
I create a one URDF file from Solidworks and i tried to rotate its joint . then i get Wrong origin of joint . i mean when i rotate joint of Robotic arm its rotate about its base joint not about its axis . i need to define cooridante frame in specific direction or need to create every joint cooridante system in specific directions
here is my URDF code :-
<?xml version ="1.0"?>
<robot name="ros_as">
<link name="world"/>
  <link name="base_link">
<inertial>
 <mass value="0.11529" />
<inertia ixx="9.8E-05" ixy="-1.15E-05"  ixz="8.6465E-05" iyy="4.444E-05" iyz="-3.4586E-05" izz="4.73321E-05" />
    </inertial>
    <visual>
      <origin xyz="0 0 0" rpy="0 -1.7 0" />
      <geometry>
        <mesh filename="package://ros_as/meshes/base_link.STL" />
      </geometry>
      <material name="">
        <color rgba="0.77647 0.75686 0.73725 1" />
      </material>
    </visual>
  </link>
  <link name="link1">
<inertial>
<inertia ixx="1.2008E-05" ixy="-4.262E-05"  ixz="-2.59095E-05" iyy="2.743395E-05" iyz="4.1807E-05" izz="2.794303E-05" />
    </inertial>
    <visual>
      <origin xyz="0.001 -0.038 0.02" rpy="-1.7 0 0" />
      <geometry>
        <mesh filename="package://ros_as/meshes/link1.STL" />
      </geometry>
      <material name="">
      </material>
    </visual>
  </link>
  <link name="link2">
<inertial>
<inertia ixx="3.46069E-05" ixy="-7.86556E-05" ixz="-1.295125E-05" iyy="7.548495E-05" iyz="1.42141E-05" izz="7.410357E-05" />
    </inertial>
    <visual>
      <origin xyz="0.001 -0.066 0.05" rpy="-1.7 0 0" />
      <geometry>
        <mesh filename="package://ros_as/meshes/link2.STL" />
      </geometry>
      <material name="">
      </material>
    </visual>
  </link>
<joint name="j0" type="fixed">
    <parent link="world" />
    <child link="base_link" />
  <origin xyz="0 0 0" rpy="0 0 0" />
</joint>
  <joint name="j1" type="revolute">
    <parent link="base_link" />
    <child link="link1" />
    <origin xyz="0.03593 0 0" rpy="-1.5708 0 1.657" />
    <axis xyz="0 0 1" />
    <limit lower="-3.14" upper="3.14" effort="20" velocity="5" />
  </joint>
  <joint name="j2" type="revolute">
    <parent link="link1" />
    <child link="link2" />
    <origin  xyz="0 -0.01 -0.03593" rpy="0 0.034067 0" />
  </joint>
<transmission name="tran0">
<type>transmission_interface/SimpleTransmission</type>
<joint name="j1">
<hardwareInterface>PositionJointInterface</hardwareInterface>
</joint>
<actuator name="motor0">
<mechanicalReduction>1</mechanicalReduction>
</actuator>
</transmission>
<transmission name="tran1">
<joint name="j2">
</joint>
<actuator name="motor1">
</actuator>
</transmission>
<gazebo>
<plugin name="control" filename="libgazebo_ros_control.so"/>
</gazebo>
</robot>
Home position joints potion
Originally posted by lagankapoor on ROS Answers with karma: 216 on 2018-03-14
Comment by Delb on 2018-03-14:
Can you edit your question to put your urdf code wiht the preformatted text (101010 button or CTRL+K) ?
Comment by lagankapoor on 2018-03-14:
@delb Done Sir
If you used the SolidWorks urdf exporter plugin this is most likely caused by the fact that your mates were not in the correct location.
Or if they were, then either the plugin failed in correctly identifying them, or you misconfigured them in the export wizard.
Originally posted by gvdhoorn with karma: 86574 on 2018-03-14
@gvdhoorn Sir i chose them Right in solidworks wizard and then after geting URDF file i manually translate links from horizontal to vertical position . is there any way to correct them ?
Comment by lagankapoor on 2018-03-15:
@gvdhoorn Sir help me to be more specific about URDF wizard information , so that i learn . in SW tutorials not explain much about that
I have solved this issue with URDF base coordinates and with its reference joint coordinates
i attached screenshot hereWorking well
Originally posted by lagankapoor with karma: 216 on 2018-03-15
