Hi to all,
I need to change the frame_id of my imu/data topic from /base_imu to base_imu. I'm using Indigo. Unfortunately, I recorded several bag files without removing the slash character now I can't run them since I always get this error message:
Warning: Invalid argument "/base_imu" passed to canTransform argument source_frame in tf2 frame_ids cannot start with a '/' like:
         at line 130 in /tmp/binarydeb/ros-indigo-tf2-0.5.15/src/buffer_core.cpp
I know that I can use bag_tools, but they do not work: if I try to install them from apt-get the package "change_frame_id" is not found, if I try to install them from source, catkin_make fails and do not build the package.
Is there any other way to change the frame_id? Can you help me, please?
Originally posted by Marcus Barnet on ROS Answers with karma: 287 on 2018-03-10
I solved the problem by copying the change_frame_id.py file inside the bag_tools folder located in /opt/ros/indigo/share/bag_tools.
Now it works.
I think the ros node installed by apt-get does not copy all the files inside the ros directory.
I opened a new issue on: https://github.com/srv/srv_tools/issues/19
Originally posted by Marcus Barnet with karma: 287 on 2018-03-10
Comment by gvdhoorn on 2018-03-11:\
have you reported this over at srv/srv_tools/issues?
Comment by Marcus Barnet on 2018-03-11:
I did it few minutes ago
Comment by gvdhoorn on 2018-03-12:
And the link to the issue?
Comment by Marcus Barnet on 2018-03-12:
You can find it in "Issues" on "srv_tools" github.
Obviously, but as a service to future readers it would be nice if you can post the link here.
Also: if your issue gets closed/resolved, it would not be immediately clear to which issue you are referring.
That way we keep things connected.
I edited the answer by adding the link to the issue.
