I install ROS 2.0 in my computer, and run the demo programs. But I can not find the log file. Where is the log file in ROS 2.0?
I know the default position in ROS 1.0 is ~/.ros.
Originally posted by Dragon on ROS Answers with karma: 68 on 2018-02-28
The logging subsystem in ROS 2 does not createa a logfile at the moment.
Originally posted by Dirk Thomas with karma: 16276 on 2018-02-28
Comment by Dragon on 2018-02-28:
Thanks for your answer. Now if I want to log into a file, how should I do? I can not find any introduction for this.
Comment by Dirk Thomas on 2018-03-02:
For now (until that feature is being implemented) you can use "standard" features available on your system. E.g. pipe the output into a file.
Comment by Dragon on 2018-03-08:
en. en. I find the function through source code. Now, it can't log in the file through the ros2.
