Just launching the robot description .
After launching freenect
roslaunch freenect_launch freenect.launch
Originally posted by chrissunny94 on ROS Answers with karma: 142 on 2018-02-28
Comment by Humpelstilzchen on 2018-03-01:
The launch file has a "publish_tf" argument, try with this argument set to false
Comment by chrissunny94 on 2018-03-01:
Did the job , thank you! (@humpelstilzchen)
[camera/camera_nodelet_manager-1] process has died [pid 12709, exit code -6, cmd /opt/ros/kinetic/lib/nodelet/nodelet manager __name:=camera_nodelet_manager __log:=/home/ubuntu/.ros/log/eeb501ca-1d10-11e8-875b-00044b65e5df/camera-camera_nodelet_manager-1.log].
log file: /home/ubuntu/.ros/log/eeb501c
Now i am getting the above error , kinect launches and then crashes
I have tried hooking it upto RPI3 , same error .
I am now using a Nvidia Jetson TX1 , still the same error persists .
Any ideas on how to get around this problem ?
When i am trying to run gmapping , i get the following error .
Timed out waiting for transform from base_link to map to become available before running costmap, tf error: Could not find a connection between 'map' and 'base_link' because they are not part of the same tree.Tf has two or more unconnec
Thats a new question, also look at the mentioned log file.
