(https://wiki.ros.org/ROS/Tutorials/UnderstandingServicesParams)
I can understand the namespace use in rosparam load [file_name] [namespace]
command in the example given, but what is the use for it in dump file generation, i tried to understand it by using double tab key, and ran this command rosparam dump roslog.yaml /background_b
it ran successfully but when i tried to load it by rosparam load roslog.yaml copy
it resulted in error :-
File "/opt/ros/kinetic/bin/rosparam", line 35, in <module>
rosparam.yamlmain()
File "/opt/ros/kinetic/lib/python2.7/dist-packages/rosparam/__init__.py", line 626, in yamlmain
_rosparam_cmd_set_load(command, argv)
File "/opt/ros/kinetic/lib/python2.7/dist-packages/rosparam/__init__.py", line 545, in _rosparam_cmd_set_load
paramlist = load_file(arg, default_namespace=script_resolve_name(NAME, arg2), verbose=options.verbose)
File "/opt/ros/kinetic/lib/python2.7/dist-packages/rosparam/__init__.py", line 174, in load_file
return load_str(f.read(), filename, default_namespace=default_namespace, verbose=verbose)
File "/opt/ros/kinetic/lib/python2.7/dist-packages/rosparam/__init__.py", line 189, in load_str
if NS in doc:
TypeError: argument of type 'int' is not iterable
Any clue on what happened and what went wrong?
Originally posted by Subhassh on ROS Answers with karma: 1 on 2018-02-22
