In a launch file I want to remap parameters of my node to other, already existing parameters. It is working for global parameters but not for private ones.
This is a simple example node "param.py":
#!/usr/bin/env python
"""Just testing parameter mapping."""
import rospy
rospy.init_node("param")
print(rospy.get_param("foo"))
print(rospy.get_param("bar"))
print(rospy.get_param("~baz"))
The node is launched by this launch file "param.launch":
<launch>
    <node name="param" pkg="mypkg" type="param.py" output="screen">
        <remap from="/bar" to="/foo" />
        <remap from="baz" to="foo" />
    </node>
</launch>
In a terminal I run:
rosparam set foo 42
roslaunch mypkg param.launch
The output is:
42
42
KeyError: '~baz'
How can I make it work?
Originally posted by Felix Widmaier on ROS Answers with karma: 382 on 2018-02-21
Comment by 130s on 2018-09-20:
I'm afraid rosparam would fail without Parameter server running. Maybe add roscore command a line above?
Private parameter names have to be prefixed with ~ even when the <remap> is defined inside the <node> tag:
<launch>
        <remap from="~baz" to="foo" />
    </node>
</launch>
Output:
42
42
42
Originally posted by Felix Widmaier with karma: 382 on 2018-02-21
Nice dig! Added to remap page.
Comment by meyerj on 2020-02-24:
Could it be that this approach does not work for roscpp nodes? The remapping is not applied for NodeHandles created as
ros::NodeHandle private_nh("~");
assert(private_nh.resolveName("baz") == "/param/foo");
with the launch file snippet from this answer.
Or is this not what to expect?
Furthermore I think what is meant by "assignment for private node parameters" in the original content of the wiki page is not remapping. Both, rospy and roscpp, support assigning parameters via "special" remappings _key:=value, but that is not the same as remapping parameter name ~key to ~value.
Found the problem with the snippet in my first post: The target of the remapping is not private, so private_nh.resolveName("baz") == "/foo", not "/param/foo".
