Hi
From what understand about launch file, <param> defined in <node> are private to that <node>. But the behaviour of my launch file doesn't look right to me. Here is the content of the launch file:
<arg name="num" default="2"/>
<param name="~num_drones" value="$(arg num)"/>
 <node name="A" pkg="drone_core" type="drone.py">
     <param name="local_name_leaked" value="leaked"/>
 </node>
 <node name="B" pkg="drone_simulator" type="sim.py">
     <param name="local_name" value="debug"/>
 </node>
Here are what rosparam list returned for A and B
/A/local_name_leaked
/A/num_drones
/B/local_name
/B/local_name_leaked
/B/num_drones
So my question is, why would "local_name_leaked" show up under /B namespace?
I'm using Jade.
Thanks
=========================== Update 1
I've narrowed down the cause. I'm reposting the full launch file for clairty
<?xml version="1.0" encoding="utf-8"?>
<launch>
    <param name="~num_drones" value="2"/>
    <!--param name="num_drones_local" value="2"/-->
        <param name="local_name_leaked" value="leaked" />
    </node>
    </node>
</launch>
With this <param name="~num_drones" value="2"/>, I get:
PARAMETERS
 * /A/local_name_leaked: leaked
 * /A/num_drones: 2
 * /B/local_name: debug
 * /B/local_name_leaked: leaked
 * /B/num_drones: 2
 * /rosdistro: jade
 * /rosversion: 1.11.21
With this <param name="num_drones_local" value="2"/> I get:
PARAMETERS
 * /num_drones_local: 2
 * /rosdistro: jade
Notice one has "~num_drones", one has "num_drones". I was assuming <param name="~num_drones" value="2"/> would create private param in any sub sequence declaration of <node> block. But is that allowed? It seems to do that, but also cause any parameter declared inside <node> block to "leak" to sub sequence <node> blocks.
Originally posted by CodingPeon on ROS Answers with karma: 21 on 2018-02-21
Comment by ahendrix on 2018-02-21:
Are you sure these parameters are being set by your launch file? Parameters persist on the roscore, so these might be left over from a previous launch file. Some nodes also set parameters, so it's possible that node B is setting this parameter.
roslaunch will print all of the parameters that it will set at startup; you should be able to see it setting (or not setting) this parameter as part of its output.
Comment by CodingPeon on 2018-02-22:
Because of character limits in reply box, I've updated the original post with my findings
The roslaunch docs for the <param> tag clearly state that this should be possible, so this looks like a bug in roslaunch.
You've provided a great sample that reproduces this already; can you create a ticket on the ros_comm issue tracket?
Originally posted by ahendrix with karma: 47576 on 2018-02-22
Comment by CodingPeon on 2018-02-24:
I've opened an issue: https://github.com/ros/ros_comm/issues/1334
