I am using ROS Kinetic with Ubuntu 16.04 LTS.
I am trying to connect two ROS nodes (publisher/subscriber, both of them). In one Python node, I am trying to use some modules I had already programmed, which are embedded in pyib2c module.
import pyib2c
This module also imports some Python modules. When I try to run my node, I receive the following error:
ImportError: cannot import name XXXXX , where XXXXX are the modules imported by my pyib2c module.
I have already uncommented the * catkin_python_setup() * in the CMakeList of my package. The setup.py is:
from distutils.core import setup
from catkin_pkg.python_setup import generate_distutils_setup
# fetch values from package.xml
setup_args = generate_distutils_setup(
    packages=['pyib2c'],
    package_dir={'': 'src'})
setup(**setup_args)
I have also created a init.py file which is:
 from . import tabulate
 from . import pyib2c
My Python node, the module pyib2c, the init.py and the setup.py are them all at the same level in my_package/src. However, it turns out to display the same mistake if I keep the pyib2c in a src folder.
How can I make my node import the modules I need?
Originally posted by FerCipri on ROS Answers with karma: 21 on 2018-02-19
Comment by jayess on 2018-02-21:
Have you compiled your package? In order for you to use the module in your package catkin needs to run your setup.py.
Comment by FerCipri on 2018-02-21:
Yes, I have run catkin_make at my catkin_ws and it works perfectly. The trouble comes at the point of rosrun my node.
The module (i.e. the source files) as well as the __init__.pyneeds to be placed in <path_to_your_package>/src/<your_package> (at least by convention and as explained in the documentation, it might work another way).
The setup.py needs to be in <path_to_your_package>.
Then catkin_python_setup should be able to find everything correctly and, hopefully, you should be able to import everything properly.
Originally posted by mgruhler with karma: 12390 on 2018-02-21
I have tried as you said and didn't work. In fact, it stopped recognising my pyib2c python module =S
Comment by mgruhler on 2018-02-22:
Did you run catkin_make once more after reorganizing? You can check if it has been installed properly if the module can be found below devel/lib/python2.7/<yourpackage>, if i am correct.
