Hi,
I'm using ROS Kinetic and a Clearpath Husky robot. I have an already running ekf_localization_node on my robot that gives me the base_link -> odom and outputs an odometry/filtered topic. Now, on the top of it, I want to use robot_localization to fuse global absolute data with markers.
I want to use the odometry data for my second ekf_global, hence I want the odometry/filtered topic to be subscribed by this node. Here is my launch file:
<?xml version="1.0"?>
<launch>
<node pkg="robot_localization" type="ekf_localization_node" name="ekf_se" clear_params="true">
<rosparam command="load" file="$(find robot_localization)/params/my_ekf.yaml" />
<remap from="odometry/filtered" to="finalpose"/>
</launch>
The param file my_ekf.yaml is below:
frequency: 30
sensor_timeout: 1
two_d_mode: true
debug: false
publish_tf: true
publish_acceleration: false
map_frame: map              # Defaults to "map" if unspecified
odom_frame: odom            # Defaults to "odom" if unspecified
base_link_frame: base_link  # Defaults to "base_link" if unspecified
world_frame: map           # Defaults to the value of odom_frame if unspecified
dynamic_process_noise_covariance: true
odom0: od
odom0_config: [true,  true,  false,
               false, false, true,
               false, false, false,
               false, false, false]
odom0_differential: false
odom0_relative: false
odom0_queue_size: 40
odom0_nodelay: false
process_noise_covariance: [0.0001, 0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0.0001, 0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0.0001, 0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0.0001, 0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0.0001, 0,    0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0.0001, 0,     0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0.0001, 0,     0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0.0001, 0,    0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0.0001, 0,    0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0.0001, 0,    0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0.0001, 0,    0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0.0001, 0,    0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0.0001, 0,    0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0.0001, 0,
                           0,    0,    0,    0,    0,    0,    0,     0,     0,    0,    0,    0,    0,    0,    0.0001]
initial_estimate_covariance: [1e-2, 0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    1e-2, 0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    1e-2, 0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    1e-2, 0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    1e-2, 0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    1e-2, 0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    1e-9, 0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    1e-9, 0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    1e-9, 0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    1e-9,  0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     1e-9,  0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     1e-9,  0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     1e-9, 0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    1e-9, 0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    1e-9]
If I look at the result of rostopic info /finalpose, I see that the ekf is subscribing to itself, but actually I am expecting to have /odometry/filtered as a subscriber. The below picture highlights this:
image description
The odometry/filtered is not empty, two_d_mode is set to true. Why does this not work? According to the wiki it should be possible to use odometry as data to be fused.
Edit
I just noticed that the remap from="odometry/filtered" caused the problem. I did remap the odometry/filtered from ekf_localization (local ekf) to a topic called /od (see Figure below) and give /od as input to ekf_global. By removing the remap tag from the .launch file I got this result,
bb
Now the layout is correct, the /od topic in not empty, and I get from the ekf_global an output (by default is called /odometry/filtered, not to be confused with the one I remapped in the ekf_localization).
But when I try to echo /odometry/filtered it says: WARNING: no messages received and simulated time is active. Is /clock being published?
Why is it empty? How can I fix this? I am expecting to see here a similar output as the pure odometry of my sensors.
I don't get it, please help me out!
Simone.
Edit2 Hi @nikfio thanks for the reply. No I am not using a wifi connection, nor a laptop hardware. I am doing all using Gazebo and simulating my Husky within it.
The output of the tf is simply odom-->base_link, but I am actually expecting to see map-->odom-->base_link, as soon as at least one input is given to my global Ekf. My final goal is to fuse AR code markers with the odometry, hence markers will correct odometry drifts at the end.
SOLVED
I finally got map-->odom-->base_link by fusing the odometry output of my local ekf_localization node. Instead of fusing absolute poses, I fused linear velocities and the yaw velocity. The I set the _relative sensor property to true, and accordingly modified the initial_state_estimate covariances to be large (value = 1) for my corresponding entries.
Above the modified .yaml file
odom0: od
odom0_config: [false,  false,  false,
               true, true, true,
              false, false, true,
odom0_relative: true
initial_estimate_covariance: [1e-9, 0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    1e-9, 0,    0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    1e-9, 0,    0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    1e-9, 0,    0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    1e-9, 0,    0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    1e-9, 0,    0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    1, 0,    0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    1, 0,    0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    1, 0,     0,     0,     0,    0,    0,
                              0,    0,    0,    0,    0,    0,    0,    0,    0,    0,     0,     1,  0,    0,    0,
Originally posted by simff on ROS Answers with karma: 98 on 2018-02-17
Comment by gvdhoorn on 2018-02-18:
@simff: please review the support guidelines. Do not post screenshots/images of text files or consoles. Copy-paste it into your question.
Comment by simff on 2018-02-18:
Yes sorry, using Windows system I had some issues with that, I could not use Linux not being at my work place. I will correct it tomorrow.
Comment by DesertXGhost on 2020-04-28:
Is it possible to print the output data of /odometry/filtered on console cause I am trying to plot it combined with a noisy data?
Standard practice would be to fuse your wheel odometry + IMU + absolute pose information in the second EKF instead of feeding the filtered odometry from the first EKF into the second EKF.
Originally posted by stevejp with karma: 929 on 2018-02-23
Comment by simff on 2018-02-23:
Hi, good point, but for my case I want to have distinct map and odom frames :)
