Who generates > nav_msg/Path local planner or global planner? If it is generated by global_planner then how local planner use it to avoid obstacle. Can we generate customized nav_msg/Path?? Actually how exactly the communication happens between global planner and local planner, using what topics or messages?
Originally posted by malgudi on ROS Answers with karma: 88 on 2018-02-13
Comment by gvdhoorn on 2018-02-13:
I'm not sure, but it seems your question is at least partially answered by wiki/navigation/Tutorials/RobotSetup (Robot Setup section).
Comment by malgudi on 2018-02-13:
Is it black box?
Comment by gvdhoorn on 2018-02-13:\
Is it black box?
I don't understand what you're saying. The diagram under "Robot Setup" shows a (terse) overview of the communication between various parts of the navigation stack. I don't see any black boxes.
Comment by mgruhler on 2018-02-13:
note that global and local planner are plugins that are loaded into a single node, move_base. So they don't actually communicate via Topics. They both have a defined API through which the respective Information is passed. They provide Topics e.g. for visualization as well as cmds, but that is it.
Comment by malgudi on 2018-02-14:
@mig is it through nav_core interfaces? Is there any extra information available on internet, journal or any book?
Comment by mgruhler on 2018-02-15:
Use Google:
Comment by gvdhoorn on 2018-02-15:
@mig: ROS Answers is for (new) users to get some guidance on how to approach and/or solve their problem(s).
Your contributions are very much appreciated, but I assume that if @mallikarjun knew what to search for he would've done that.
Perhaps you could extend your comment a bit and post an answer?
@gvdhoorn @mallikarjun sorry, if my comment was a bit harsh. it wasn't intended to be like that.
Comment by malgudi on 2018-02-15:
@mig @gvdhoorn Thank you for your replies. I am new to ROS and learning everyday, so sometimes I ask foolish question. I am thankful to ROS community for providing this platform, otherwise It would have been very difficult.
I'll try to answer the questions in order.
All assuming you use the Standard move_base structure as linked to by @gvdhoorn above.
Both, but actually just for visualization. Typically on something like move_base/<PLANNER>/<local_/global_>plan topics. The local planner also generates a geometry_msgs/Twist message which provides the commanded velocities to the robot.
It is passed from the global planner to the local planner through the nav_core Interfaces.
Sure, as both local_planners and global_planners are plugins to move_base you can write your own plugin which creates the plan in a way that you want. Some more Information about how to do this can be found in the Tutorials or here, for example.
As stated above, this happens through the defined nav_core interfaces. For more Details, please refer to the API documentation on the wiki page.
Is it black box?
No, as this is, as all of ROS, OSS. Check the links to the API documentation as well as the github repos on the respective wiki pages.
Originally posted by mgruhler with karma: 12390 on 2018-02-15
Thank you very much.
