Hello and thanks for reading my post. I am trying to subscribe to a topic from an imu using the sensor_msgs::MagneticField. This topic is published by a 3rd party package called mavros. I am trying to edit the subscriber script from the tutorial, but have some issues printing the data with the ROS_INFO command. I am not sure if I am subsribing to the topic incorrectly, or if it's only an issue with my usage of ROS_INFO. I am trying to print the x variable of the message but the output message looks like this:
[ INFO] [1518093660.171431954]: I heard: [H?H0?`? ]
The documentation for the MagneticField message is here
My code looks like this
#include "ros/ros.h"
#include "sensor_msgs/MagneticField.h"
void chatterCallback(const sensor_msgs::MagneticField::ConstPtr& mag)
  ROS_INFO("I heard: [%s]", mag->magnetic_field.x);
  ros::init(argc, argv, "listener");
  ros::NodeHandle n;
  ros::Subscriber sub = n.subscribe<sensor_msgs::MagneticField>("/mavros/imu/mag", 1000, chatterCallback);
  ros::spin();
  return 0;
Originally posted by eirikaso on ROS Answers with karma: 108 on 2018-02-08
I found the error. I had to change the [%s] with [%f] for float. Silly mistake
Originally posted by eirikaso with karma: 108 on 2018-02-08
