Hello,
I want to publish a path, but with this code I can publish only one point at a time: geometry_msgs::Point msg;
What can I do to publish the path? This page should work, but I don't know exactly how to write the code for it. http://docs.ros.org/api/nav_msgs/html/msg/Path.html
Can you help me out? Thank you
Originally posted by Chris_ROSuser on ROS Answers with karma: 31 on 2018-02-08
To fill that kind of messages, create a geometry_msgs/PoseStamped and then insert it in the vector poses in the nav_msgs/Path message.
Note that in C++, an variable length array is a std::vector.
So it should look like:
nav_msgs::Path path;
geometry_msgs::PoseStamped pose;
pose.header.stamp = ...;
pose.header.frame_id = ...;
pose.pose.position.x = ...;
path.header.stamp = ...;
path.header.frame_id = ...;
path.poses.push_back(pose);
Originally posted by rreignier with karma: 544 on 2018-02-08
Post score: 5
Comment by aarontan on 2018-06-16:
once you publish a path, how do you make a robot follow the published path in rviz? I am using this package to publish predefined paths but my robot wont move along the path...
Comment by rreignier on 2018-06-25:
@aarontan It is a complex subject. Maybe you can start here: http://wiki.ros.org/navigation
