I am building a G-mapping based SLAM robot .
Master - This is my desktop .
  • roscore is running here
  • 192.168.1.6 is the IP address
Robot - The robot is hooked to a RPI3 .
  • I have added this to the .bashrc file , "export ROS_MASTER_URI=http://192.168.1.6:11311"
  • IP address of the RPI is "192.168.86.165"
I am publishing /clock (which is required for the node publishing /odom) from the RPI on the Robot .
I am not able to receive the /clock on the Master .
Essentially the client is not able to communicate back with the master , how do i fix it .
Originally posted by chris_sunny on ROS Answers with karma: 47 on 2018-02-07
Have you set ROS_IP on both hosts?
Edit:
Should i set the ROS_IP on both Master and Client ?
Unless you have a working DNS setup for both: yes.
Note: if you have DHCP configured, adding the (current) IP addresses to /etc/hosts is not sufficient, as the IPs may change in the future / on reboot. If you have DHCP, make sure to have proper DNS as well (ie: updated by your DHCP server).
And just making sure: have you checked the ROS/NetworkSetup guide?
Edit2:
On the robot instead of export ROS_IP=192.168.86.165, it was export ROS_IP=localhost
I would be very much surprised if that works. It could work now, but I guarantee you that you'll get in trouble later.
Originally posted by gvdhoorn with karma: 86574 on 2018-02-07
Comment by chris_sunny on 2018-02-07:
Thanks , problem solved . On the robot instead of export ROS_IP=192.168.86.165 , it was export ROS_IP=localhost
