Hi all,
I want to use several libraries created in one package, let say package A, into package B. Both packages' bareboned CMakeLists look like this:
A : The package in which my custom libraries reside:
CMakeLists.txt
project(A)
catkin_package(
  INCLUDE_DIRS include
  LIBRARIES killer_utils_lib
             haha_lib
  CATKIN_DEPENDS ... <-- just a simplification
  DEPENDS ...
include_directories(
  include
  ${catkin_INCLUDE_DIRS}
add_library(killer_utils_lib src/killer_utils.cpp )
add_library(haha_lib src/haha.cpp)
target_link_libraries(killer_utils_lib
  ${catkin_LIBRARIES}
target_link_libraries(haha_lib
  ${catkin_LIBRARIES}
install(TARGETS
  killer_utils_lib
  haha_lib
  ARCHIVE DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
  LIBRARY DESTINATION ${CATKIN_PACKAGE_LIB_DESTINATION}
  RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION}
  PUBLIC_HEADER DESTINATION ${CMAKE_INSTALL_INCLUDEDIR}
install(DIRECTORY include/${PROJECT_NAME}/
  DESTINATION ${CATKIN_PACKAGE_INCLUDE_DESTINATION}
  FILES_MATCHING PATTERN "*.h"
  PATTERN ".svn" EXCLUDE
B : The package to which I want to import my custom libraries
CMakeLists.txt
project(B)
  killer_utils_lib
  haha_lib
catkin_package(
include_directories(include)
  ${killer_utils_lib_INCLUDE_DIRS}
  ${haha_lib_INCLUDE_DIRS}
add_executable(example src/example.cpp)
target_link_libraries(example ${catkin_LIBRARIES} killer_utils_lib haha_lib)
package.xml in B
<build_depend>killer_utils_lib</build_depend>
<build_depend>haha_lib</build_depend>
If I put these two files to compile, The following error messages will pop up:
CMake Warning at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:76 (find_package):
  Could not find a package configuration file provided by "killers_utils_lib"
  with any of the following names:
    killer_utils_libConfig.cmake
    killer_utils_lib-config.cmake
  Add the installation prefix of "killer_utils_lib" to CMAKE_PREFIX_PATH or
  set "killer_utils_lib_DIR" to a directory containing one of the above
  files.  If "killer_utils_lib" provides a separate development package or
  SDK, be sure it has been installed.
  task/decision_tasks/CMakeLists.txt:7 (find_package)
-- Could not find the required component 'killer_utils_lib'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
CMake Error at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
  Could not find a package configuration file provided by "killer_utils_lib"
My question is, I've followed the steps as given in this ROS Answer article, why do my custom shared libraries killer_utils_lib and haha_lib still not be seen by other packages?
Originally posted by Megacephalo on ROS Answers with karma: 106 on 2018-01-31
Because the cmake config gets generated for the package and not for each lib seperately.
So you need to find_package your package A. The environment variables (e.g. A_LIBRARIES) are then populated with the libraries inside the package.
To cite the question you link to:
• have a build_depend on my_package in its package.xml
• have called find_package(my_package REQUIRED) in its CMakeLists.txt
Originally posted by mgruhler with karma: 12390 on 2018-01-31
Comment by Megacephalo on 2018-02-01:
Thank you @mig!! Now I understand better how this building mechanism works!! Now the libraries can be imported into another package!
