I am trying to get yaw pitch roll from an MPU6050 imu using the following code(some parts of code removed for clarity). Its getting uploaded
  #include <I2Cdev.h>
  #include <Wire.h>
  #include <MPU6050.h>
  #include <ros.h>
  #include <geometry_msgs/Vector3.h>
  ros::NodeHandle nh;
  geometry_msgs::Vector3 yaw_pitch_roll;
  ros::Publisher pubyaw_pitch_roll("yaw_pitch_roll", &yaw_pitch_roll);
  MPU6050 mpu;
  // Timers
  unsigned long timer = 0;
  float timeStep = 0.01;
  // Pitch, Roll and Yaw values
  float pitch = 0;
  float roll = 0;
  float yaw = 0;
  void setup()
    nh.initNode();
    nh.advertise(pubyaw_pitch_roll);
     //main problem here
      mpu.calibrateGyro();
  void loop()
    timer = millis();
    yaw_pitch_roll.x = yaw;
    yaw_pitch_roll.y = pitch;
    yaw_pitch_roll.z = roll;
    pubyaw_pitch_roll.publish( &yaw_pitch_roll );
    nh.spinOnce();
    delay(100);
But when i try to run the following command in terminal after uploading:
rosrun rosserial_python serial_node.py /dev/ttyACM0 _baud:=57600
I get the following error:
[ERROR] [1517073128.320418]: Unable to sync with device; possible link problem or link software version mismatch such as hydro rosserial_python with groovy Arduino
Now, I have run many arduino programs using same configurations( baud_rate) and commands. But this is the only program thats giving me a tough time.
Also when i remove the following line: mpu.calibrateGyro(); the program runs fine.
Can anyone suggest me any workaround for this?
NOTE: I have tried to change the baudrate to 115200 and serial port is also right(other programs run fine) and message is not too big( i have sent the same message in other programs)
Originally posted by khansaadbinhasan on ROS Answers with karma: 94 on 2018-01-27
Comment by lagankapoor on 2018-01-30:
Answer is working for you ?
Comment by khansaadbinhasan on 2018-01-30:
No. In the second link it is mentioned to run many commands. Everything works fine till ./configure After this I suppose an error crawls in here: checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes /tmp/bcm2835-1.50/missing: Unknown --is
after this when i try to run make its giving me many warnings and when i try to run make check its showing Testsuite summary for bcm2835 1.50 ============================================================================ # TOTAL: 1 # PASS: 0 # SKIP: 0 # XFAIL: 0 # FAIL: 1 # XPASS: 0
bro i not work on that till now so i don't know much Sorry
Here is the the solution for your problem https://github.com/superjax/tinyIMU_arduino https://github.com/chrisspen/ros_mpu6050_node Only need to do some modification according to needs
Originally posted by lagankapoor with karma: 216 on 2018-01-29
