I would like to run two ROS2 nodes, let's say listener and talker from the demo_nodes_cpp package each in a docker container (osrf/ros2:ardent-basic image).
Originally posted by thinwybk on ROS Answers with karma: 468 on 2018-01-25
The easiest approach will be to setup the two containers to be on the same network segment. There's lots of ways to do this the docker networking documentation is here: https://docs.docker.com/engine/userguide/networking/
You'll likely want to use Docker Compose to automate the multi container launching. I recommend reading the Docker Compose Documenation
Update: @gvdhoorn is right that the new docker behavior is to default to running the containers on the same network.
I verifed I can just run this on one terminal
$ docker run -ti --rm osrf/ros2:ardent-full ros2 run examples_rclcpp_minimal_publisher publisher_member_function
[INFO] [minimal_publisher]: Publishing: 'Hello, world! 0'
[INFO] [minimal_publisher]: Publishing: 'Hello, world! 1'
[INFO] [minimal_publisher]: Publishing: 'Hello, world! 2'
[INFO] [minimal_publisher]: Publishing: 'Hello, world! 3'
[INFO] [minimal_publisher]: Publishing: 'Hello, world! 4'
[INFO] [minimal_publisher]: Publishing: 'Hello, world! 5'
[INFO] [minimal_publisher]: Publishing: 'Hello, world! 6'
And in a 2nd terminal:
$ docker run -ti --rm osrf/ros2:ardent-full ros2 run examples_rclpy_minimal_subscriber subscriber_member_function
[INFO] [minimal_subscriber]: I heard: "Hello, world! 34"
[INFO] [minimal_subscriber]: I heard: "Hello, world! 35"
[INFO] [minimal_subscriber]: I heard: "Hello, world! 36"
[INFO] [minimal_subscriber]: I heard: "Hello, world! 37"
Originally posted by tfoote with karma: 58457 on 2018-01-25
Comment by gvdhoorn on 2018-01-26:
Shouldn't this work out-of-the-box? All containers get placed on the same network in a default Docker network configuration.
Comment by thinwybk on 2018-01-27:
@gvdhoorn @tfoote The network config was not clear to me. @tfoote Thanks for the snippet. BTW: The example can be executed with the image osrf/ros2-basic as well.
