after i install rtabmap from source when i try to run it i got this error: [ WARN] [1516726659.614500547]: /rtabmap/rtabmap: Did not receive data since 5 seconds! Make sure the input topics are published ("$ rostopic hz my_topic") and the timestamps in their header are set. If topics are coming from different computers, make sure the clocks of the computers are synchronized ("ntpdate"). If topics are not published at the same rate, you could increase "queue_size" parameter (current=10). /rtabmap/rtabmap subscribed to (approx sync): /rtabmap/odom, /camera/rgb/image_rect_color, /camera/depth_registered/sw_registered/image_rect_raw, /camera/rgb/camera_info
rostopic hz /rtabmap/odom: subscribed to [/rtabmap/odom] no new message rostopic hz /camera/rgb/image_rect_color subscribed to [/camera/rgb/image_rect_color] no new messages rostopic hz /camera/depth/image_rect_color WARNING: topic [/camera/depth/image_rect_color] does not appear to be published yet
so what i can do to resole this issues
Originally posted by abdelkrim on ROS Answers with karma: 9 on 2018-01-23
With zed camera, the depth image topic would be something like this: /camera/depth/depth_registered. You may want to try Zed related instructions on this page.
cheers
Originally posted by matlabbe with karma: 6409 on 2018-01-23
Comment by abdelkrim on 2018-01-24:
@matlabbe i tried it all but i get the same issue
Comment by matlabbe on 2018-01-24:
Try "$ rostopic hz my/topic" on needed topics to know if they are actually published. You can also start only the zed, then do "$ rostopic list" to list all available topics and copy/paste them in your question.
When i run only zed i get all topic available
... and are they published? (use rostopic hz)
Comment by abdelkrim on 2018-01-26:
@matlabbe i can see the image when i run rqt_image_view
but no data published in rostopic hz my/topic
the issue resolved just in rtabmapviz but not in rviz
