Hi,
I tried to spawn multiple controllers in Gazebo.Related launch file and config files are attached here. I am able to see the topic names ,but when i publish the values through command line,respective joints are not moving in Simulation.
Launch file:
<rosparam file="$(find marvin_description)/config/marvin.yaml" command="load"/>
<rosparam file="$(find marvin_description)/config/jaco.yaml" command="load"/>
<node name="controller_spawner" pkg="controller_manager" type="spawner" respawn="false"
output="screen" ns="/marvin" args="linear_actuator_controller joint_state_controller ptu_pan_controller ptu_tilt_controller jaco2_controller jaco2_gripper_controller"/>
Config .yaml file:
marvin:
# Publish all joint states -----------------------------------
joint_state_controller:
type: joint_state_controller/JointStateController
publish_rate: 50
# Position Controllers ---------------------------------------
linear_actuator_controller:
type: position_controllers/JointPositionController
joint: marvin_linear_actuator_joint
pid: {p: 100.0, i: 0.01, d: 1.0}
ptu_pan_controller:
joint: ptu_pan
pid: {p: 100.0, i: 0.01, d: 10.0}
ptu_tilt_controller:
joint: ptu_tilt
jaco.yaml
marvin:
jaco2_controller:
type: effort_controllers/JointTrajectoryController
joints:
- jaco2_joint_1
- jaco2_joint_2
- jaco2_joint_3
- jaco2_joint_4
- jaco2_joint_5
- jaco2_joint_6
gains:
jaco2_joint_1: {p: 500.0, d: 50.0}
jaco2_joint_2: {p: 800.0, d: 50.0}
jaco2_joint_3: {p: 350.0, d: 30.0}
jaco2_joint_4: {p: 300.0, d: 3.0}
jaco2_joint_5: {p: 500.0, d: 3.0}
jaco2_joint_6: {p: 200.0, d: 30.0}
constraints:
goal_time: 5.0
jaco2_joint_1:
goal: 0.05
trajectory: 0.10
jaco2_joint_2:
goal: 0.05
trajectory: 0.10
jaco2_joint_3:
goal: 0.05
trajectory: 0.10
jaco2_joint_4:
goal: 0.05
trajectory: 0.10
jaco2_joint_5:
goal: 0.05
trajectory: 0.10
jaco2_joint_6:
goal: 0.05
trajectory: 0.10
jaco2_gripper_controller:
joints:
- jaco2_joint_finger_1
- jaco2_joint_finger_2
gains:
jaco2_joint_finger_1: {p: 100.0, d: 1.0}
jaco2_joint_finger_2: {p: 100.0, d: 1.0}
Originally posted by ARB on ROS Answers with karma: 51 on 2018-01-20
