Hello everyone, I have question about if it possible for one ROS system to do an exploring (Raspberry pi) and transfer data to other ROS system (LINUX) To Use SLAM to draw a map ? if yes, can someone tells me the main idea or how to start Thank you
*Because i have seen communication between two ROS system, but i was not sure if is it possible to the extension of using SLAM and RVIZ to have the map on the other machine
Originally posted by Mohammedism on ROS Answers with karma: 32 on 2018-01-19
Comment by jayess on 2018-01-19:
What do you mean by
two ROS systems
? Two computers both running ROS on the same network with the same Master? Something else?
Comment by Mohammedism on 2018-01-19:
What i mean a Raspberry pi with Jessie OS on it, that runs ROS
but since the Raspberry pi can not handle RVIZ
I will run RVIZ on another computer
