Is there a way to define a ROS message or service with arbitrary python objects? Is the only option to use a string and use json.dumps / json.loads?
Originally posted by waspinator on ROS Answers with karma: 122 on 2018-01-19
Assuming you mean: can I have fields with types of 'arbitrary Python types', then: no.
Don't know whether it's the only way, but it is a way.
Can you clarify why you'd want to do this?
It's a really heavy and invasive form of coupling, which limits reusability of your components.
Originally posted by gvdhoorn with karma: 86574 on 2018-01-19
Comment by waspinator on 2018-01-20:
I use a python ORM to read/write to a database, and I was considering having a ROS node with services for each database operation. I could a) send the python object to the service to save, b) send just the properties and have the service create a new object, or c) use the ORM directly. not sure.
Comment by gvdhoorn on 2018-01-21:
In any case: ROS 1 msg IDL only supports primitive types or composites of those types. See wiki/msg.
