Hey :-)
System: Ubuntu 16.04
ROS: Lunar (tried Kinetic before) Desktop Full
rtabmap version : 0.13.2
My approach ist to use the rtabmap feature in cooperation with Tango ROS Streamer which is already running fine.
I followed the instructions on this tutorial :
http://wiki.ros.org/rtabmap_ros/Tutorials/Tango%20ROS%20Streamer
At step 6 it fails at this command
rosrun rtabmap_ros pointcloud_to_depthimage cloud:=/tango/point_cloud camera_info:=/tango/camera/color_1/camera_info _fixed_frame_id:=start_of_service _decimation:=8 _fill_holes_size:=5
with the error:
[rosrun] Couldn't find executable named pointcloud_to_depthimage below /opt/ros/lunar/share/rtabmap_ros
I already installed rtabmap via:
sudo apt install ros-lunar-rtabmap-ros
What could go wrong ? -_-
best regards and many thanks in advance for any help
Mark
Originally posted by Markovicho on ROS Answers with karma: 15 on 2018-01-19
Comment by PeteBlackerThe3rd on 2018-01-19:
Did you get any errors when you installed rtabmap? Have your sourced the setup.bash file for ros?
Comment by Markovicho on 2018-01-19:
No errors on the installation... setup.bash is attached to my ~/.bashrc as well running "rosdep init && rosdep update"
I have already seen the same error, but forgot to write an error report. pointcloud_to_depthimage seems not to be included in the deb package or is not installed. I've compiled rtabmap from source.
Originally posted by ChriMo with karma: 476 on 2018-01-22
Comment by Markovicho on 2018-01-22:
Thanks a lot !!!
This worked:
