Hi, I am relatively new to ROS and have a question regarding Publisher and Subscriber.
To make this easy I use the Code from the ROS Tutorial "Writing a Simple Publisher and Subscriber (C++)". I can get everything to run and I can see the published messages through the "listener" node.
My question now is, how can I get the messages from the "chatterCallback" function back into my main function because I want to use it with Data from the main. I looked into the documentation of "subscribe" but I cant get it to work.
Maybe I cant see the obvious solution because I didn't programmed for a while now.
Used Code: http://wiki.ros.org/ROS/Tutorials/WritingPublisherSubscriber%28c%2B%2B%29
#include "ros/ros.h"
#include "std_msgs/String.h"
void chatterCallback(const std_msgs::String::ConstPtr& msg)
  ROS_INFO("I heard: [%s]", msg->data.c_str());
  ros::init(argc, argv, "listener");
  ros::NodeHandle n;
  ros::Subscriber sub = n.subscribe("chatter", 1000, chatterCallback);
  //here I want access to the message from chatterCallback
  ros::spin();
  return 0;
Thank you for the answers.
Originally posted by Slevin Kelevra on ROS Answers with karma: 1 on 2018-01-18
Comment by jayess on 2018-01-18:
Welcome! What does
mean? What have you tried (post your code please)?
Comment by Slevin Kelevra on 2018-01-18:
I edited the post.
What you can do is create a global variable to store the data in. For example
std_msgs::String str_var; // global variable
  str_var.data = msg->data; // save the data in the callback
  ros::NodeHandle n;
  ros::spin();
  return 0;
Ideally, you'd create a class for this and save the data to a class variable instead of a global one.
Note that I haven't compiled the code so there may be some errors, but the main idea is there.
Originally posted by jayess with karma: 6155 on 2018-01-18
Comment by gvdhoorn on 2018-01-18:
Note btw that this (as all examples given on questions about 'using msgs in main') diverges from the purely event-based style of control-flow that asynchronous systems such as ROS pub-sub make possible/are proponents of.
Attempting to treat it as a synchronous, sampling, periodic while-loop is ..
.. obviously possible, but may lead to unexpected behaviour and even subtle bugs.
See this ROSCon17 presentation about something similar.
I knew that I could use a global variable but I learned that global variables should be avoided if possible.
I try your idea with the class tomorrow but it sounds promissing.
To the problem with the asynchronous system: would it be a solution when I build a queue in the class to accumulate all ...
...messages till I get them from the main function?
Comment by thejose on 2020-08-14:
I understand that there could be errors if no message is received and the code in main calls the message. However, I don't see how this problem is solved using a class variable instead of a global variable.
Also, what is the most ideal way to solve this problem? I am sure it is quite common for people to want to access messages from a topic, manipulate them and publish the output to another topic. There must be a standard way to do this.
Comment by gvdhoorn on 2020-08-14:\
Yes:
  1. store them in a work-queue or a message_filters/Cache and have a separate thread process the queue, or
  2. do the work in the callback and publish as soon as you have processed the message
