running on ubuntu 16.04 ros kinetic on catkin_make i get this error. there is a arm_interface.h file in omer/src/inclue/omer
 /home/armadillo2/catkin_ws/src/omer/src/arm_interface.cpp:2:50: fatal error: armadillo_hl_interface/arm_interface.h: No such file or directory
    compilation terminated.
    /home/armadillo2/catkin_ws/src/omer/src/robot_test.cpp:5:50: fatal error: armadillo_hl_interface/arm_interface.h: No such file or directory
    omer/CMakeFiles/robot_testing.dir/build.make:62: recipe for target 'omer/CMakeFiles/robot_testing.dir/src/arm_interface.cpp.o' failed
    make[2]: *** [omer/CMakeFiles/robot_testing.dir/src/arm_interface.cpp.o] Error 1
    make[2]: *** Waiting for unfinished jobs....
    omer/CMakeFiles/robot_testing.dir/build.make:86: recipe for target 'omer/CMakeFiles/robot_testing.dir/src/robot_test.cpp.o' failed
    make[2]: *** [omer/CMakeFiles/robot_testing.dir/src/robot_test.cpp.o] Error 1
    CMakeFiles/Makefile2:9581: recipe for target 'omer/CMakeFiles/robot_testing.dir/all' failed
    make[1]: *** [omer/CMakeFiles/robot_testing.dir/all] Error 2
    Makefile:138: recipe for target 'all' failed
    make: *** [all] Error 2
    Invoking "make -j4 -l4" failed
cmake:
project(omer)
  roscpp
  rospy
  std_msgs
  moveit_core
  moveit_ros_planning
  moveit_ros_planning_interface
  actionlib_msgs
  actionlib
  tf
include_directories(include ${catkin_INCLUDE_DIRS})
generate_messages(
  DEPENDENCIES std_msgs geometry_msgs actionlib_msgs
package.xml
<?xml version="1.0"?>
<package format="2">
  <name>omer</name>
  <version>0.0.0</version>
  <description>The omer package</description>
  <maintainer email="[email protected]">armadillo2</maintainer>
  <license>TODO</license>
  <buildtool_depend>catkin</buildtool_depend>
  <build_depend>roscpp</build_depend>
  <build_depend>std_msgs</build_depend>
  <build_depend>actionlib</build_depend>
  <build_depend>actionlib_msgs</build_depend>
  <build_depend>tf</build_depend>
  <build_depend>moveit_core</build_depend>
  <build_depend>moveit_ros_planning</build_depend>
  <build_depend>moveit_ros_planning_interface</build_depend>
  <build_depend>moveit_msgs</build_depend>
  <build_depend>arm_interface</build_depend>
  <build_export_depend>roscpp</build_export_depend>
  <build_export_depend>rospy</build_export_depend>
  <build_export_depend>std_msgs</build_export_depend>
  <exec_depend>actionlib</exec_depend>
  <exec_depend>actionlib_msgs</exec_depend>
  <exec_depend>tf</exec_depend>
  <exec_depend>roscpp</exec_depend>
  <exec_depend>rospy</exec_depend>
  <exec_depend>std_msgs</exec_depend>
  <exec_depend>moveit_core</exec_depend>
  <exec_depend>moveit_ros_planning</exec_depend>
  <exec_depend>moveit_ros_planning_interface</exec_depend>
  <exec_depend>moveit_msgs</exec_depend>
 <exec_depend>arm_interface</exec_depend>
  <export>
  </export>
</package>
Originally posted by omer91 on ROS Answers with karma: 60 on 2018-01-08
The #include statements in both arm_interface.cpp and robot_test.cpp seem to be looking for a header file called arm_interface.h which must be inside a directory called armadillo_hl_interface. Since this isn't the directory that contains that header file it's failing.
From your description the file is actually located in the omer/src/include/omer directory so try changing the #include in the two source files to:
#include "omer/arm_interface.h"
Hopefully then it will be able to find the header files correctly.
Originally posted by PeteBlackerThe3rd with karma: 9529 on 2018-01-08
Post score: 5
Comment by omer91 on 2018-01-08:
thanks that solved it!
Comment by jayess on 2018-01-08:
If this solved your problem then please click the checkmark to mark the answer as correct.
