Hi I have got a problem with publish data. I want to publish msg.linear.x and msg.linear.y to V-REP via ROS.
When I write in terminal
rostopic pub -1 /cmd_vel geometry_msgs/Twist '{linear: {x: -3.0, y: -3.0}}'
Everything is ok, but I want to publish this from PYTHON.
My actually code is:
#!/usr/bin/env python
import rospy
#added
from geometry_msgs.msg import Twist
def callback(data):
    global msg
    if data.data=="Unknown":
        pub = rospy.Publisher('cmd_vel', Twist)
        rospy.loginfo("Classifiers output: %s in unknown" % data.data)
        msg.linear.x = 2
        msg.linear.y = 2
        msg.angular.z = 0
        speed = 0.4
        rospy.loginfo("checking for cmd" + str(msg.linear))
        pub.publish(msg)
    elif data.data=="Check":
        rospy.loginfo("Classifiers output: %s in check" % data.data)
    else:
        rospy.loginfo("Classifiers output: %s and not unknown or check" % data.data)
def listener():
     global msg
     rospy.init_node('listener', anonymous=True)
     msg = Twist()
     rospy.Subscriber("ccc", String, callback)
     rospy.spin()
if __name__ == '__main__':
    listener()
I am newbie in Python. Above code, I found on the Internet, and I try to translate into my case. What I want to do? I want to have control model in V-REP, by ROS. I can control by terminal thanks for egzample:
but I want control this model via Python, but I dont know how to do this :/
Thanks for suggestion
Originally posted by aefka on ROS Answers with karma: 15 on 2018-01-05
Comment by jayess on 2018-01-05:
What is your question/problem? Is your code not working as expected?
Comment by aefka on 2018-01-05:
Yes :/ I want to publish msg.linear.x = 2 msg.linear.y = 2 from python. I am newbie in this language :/
If you're having any issues with the publishing, part of the problem may be that you're creating your publisher inside of your callback function. What you should do is create it inside your listener function so you're not re-instantiating it every time your a message is published on the /ccc topic.
For example:
import rospy
#added
def callback(data):
    global msg
    global pub
        msg.linear.x = 2
        msg.linear.y = 2
        msg.angular.z = 0
        speed = 0.4
        pub.publish(msg)
    else:
def listener():
     global msg
     msg = Twist()
     global pub
     pub = rospy.Publisher('cmd_vel', Twist, queue_size=10) # move instantiation of publisher
     rospy.spin()
    listener()
Although, what you most likely would want to do is create a class to do this since the use of globals isn't always the greatest of ideas.
Originally posted by jayess with karma: 6155 on 2018-01-05
Ok, but I want to topic 'cmd_vel' publish msg.linear.x and msg. linear.y
What do you mean? The pub publisher is sending Twist messages along the /cmd_vel topic.
But in this case, which messages are sending? I want send such messages to set velocities in V-REP
thanks rostopic pub I set velocities, and I have to do the same by Python
Alright, I was just going along with what you had stated earlier
the "this" being the Twist message. I have never used V-REP before.
ok, maybe on the other hand. How can I write rostopic pub -1 /cmd_vel geometry_msgs/Twist '{linear: {x: -3.0, y: -3.0}}' in python?
only no os.system :D
That's what we did here. You should go through the Python subscriber/publisher tutorials
I saw this, but I still have got problems with this :/ Unfortunately with your corrections, the model still does not move
Thanks for trying :)
You can always ask a new question regarding that specific problem
