Hi,
I'm using the mavros package but I'm not sure on how to use a certain message type. I want to use this: setpoint_raw/local (mavros_msgs/PositionTarget) message type and want to set the FRAME_BODY_OFFSET_NED flag, but I'm not sure on how to do it. Can someone explain this to me?
I was also planning to use the velocity part of the message, but thats quite simple. I will do it as folow:
vel_msg.velocity.x = 0.1;
vel_msg.velocity.y = 0.0;
vel_msg.velocity.z = 0.0;
Of cours I will first declare the publisher and the message.
Message type
Mavros
Thanks!
Originally posted by MaximeRector on ROS Answers with karma: 60 on 2017-12-23
FRAME_BODY_OFFSET_NED is a flag that's defined in the message. By convention, flags should have the same prefix as the message field that they relate to. In this case the FRAME_* flags are directly below the coordinate_frame field, so they appear to be related. A quick Google search reveals a code snippet that confirms this hypothesis:
moveMsg.coordinate_frame = mavros_msgs::PositionTarget::FRAME_BODY_OFFSET_NED;
Happy roboting!
Originally posted by clyde with karma: 1247 on 2017-12-24
