I am a beginner at ROS and ROS navigation stack.
I have been using roomba_500_series and navigation stack (including move_base module). I would like to subscribe to /bumper topic in move_base. The topic type of /bumper is roomba_500_series/Bumper. I can already use bumper topic by using kobuki_bumper2pc. However I want to use the topic in move_base one way or another.
First of all, I would like to try to turn rommba left when the right bumper is true after publishing /cmd_vel. I modified move_base.cpp like below.
move_base.cpp (line: 902~) link text
//make sure that we send the velocity command to the base
 vel_pub_.publish(cmd_vel);
//***modified part
 bump_sensor_sub_ = nh.subscribe("/bumper", 1000, &MoveBase::BumperSensorCB, this);
 if (right_bumper==1){
    publishZeroVelocity();
    while(right_bumper==1){
       cmd_vel.linear.x = 0.0;
       cmd_vel.linear.y = 0.0;
       cmd_vel.angular.z = 0.78;
function MoveBase::BumperSensorCB which I made
void MoveBase::BumperSensorCB(const roomba_500_series::Bumper::ConstPtr& msg)
    left_bumper = msg->left.state;
    right_bumper = msg->right.state;
right_bumper & left_bumper are boolean data type
bool right_bumper, left_bumper;
I modified move_base.cpp as noted above. However roomba doesn't work as I thought. It seems like MoveBase can't subscribe to /bumper topic now. Although, the cause might be CMakeLists.txt , I have no idea how to modify it to use /bumper topic from roomba_500_series.
Sorry that was such a long post and my poor English.
I would appreciate it if you could answer my question.
Thank you.
Originally posted by rostaro on ROS Answers with karma: 17 on 2017-12-11
Comment by jayess on 2017-12-20:
Why did you modify move_base.cpp? Modifying source code as you did is generally not a good idea. If/when you update this package your modification will be gone.
Comment by rostaro on 2017-12-21:
I am trying to create new state_ link text in MoveBase::executeCycle. When /bumper's state is unavoidably true, I'd like to control roomba in new state_.
The modifying code above is to confirm whether it works or not on an experimental basis. I am not a engineer, so I have no idea, it is good or not.
You are subscribing to the same topic in a while.
You have to subscribe only once.
Since you are already subscribing to the node before the while, try to remove the bump_sensor_sub_ = nh.subscribe("/bumper", 1000, &MoveBase::BumperSensorCB, this); that is inside the while(right_bumper==1){} and see if it works.
Originally posted by Ruben Alves with karma: 1038 on 2017-12-11
Comment by rostaro on 2017-12-20:
Thank you for answering my question and I`m sorry for the delay in my reply.
Actually, I am subscribing the same topic in a while. My intention is to exit the while by updating bumper data. Therefor, I am doing it. Please excuse my lack of explanation.
In terms of this question that I have posted, I have already solved the problem. The cause might be CmakeLists.txt. I appreciate your understanding and cooperation. Please excuse any mistakes in this letter. Thank you.
