After implementing SLAM using gmapping, the map was saved using map_server package, as a pgm file and a yaml file, I need to know the dimensions of the objects in the map and the map itself, how do I achieve this?
Originally posted by fiorano10 on ROS Answers with karma: 45 on 2017-12-06
Get the dimensions of the pgm (x pixels by y pixels) then examine your yaml file. In the yaml file the resolution of the map is given in meters/pixel. This will allow you to determine the size of your map in meters. You would figure out the size of objects in the map in a similar fashion (i.e., multiply the number of pixels your object takes by the resolution of your map and you'll have the physical size of the object).
Refer to http://wiki.ros.org/map_server#YAML_format
Originally posted by jayess with karma: 6155 on 2017-12-06
Comment by fiorano10 on 2017-12-06:
What are some ways I could get the x and y pixels for the map and not the pgm file? My pgm file has larger dimensions than the actual map.
Comment by jayess on 2017-12-06:
You can just manually edit the pgm so that it is the size of your map. I've used GIMP to edit maps before.
