Hello I am trying to build a Quadcopter for a school project and I need to finish quick before our mission trip because I was asked to finish it before then so that I could take it. But I am having a problem figuring out which charger would work with my ZIPPY Compact 6200mAh 4s 40c Lipo Pack
Here are the specs on the battery
- Capacity: 6200mAh
- Voltage: 4S1P / 4 Cell / 14.8V
- Discharge: 40C Constant / 50C Burst
- Weight: 589g (including wire, plug & case)
- Dimensions: 158x46x41mm
- Balance Plug: JST-XH Discharge Plug: HXT4mm
Also I will be running the Tarot T4-3D Brushless Gimbal for GoPro (3-Axis) and if anyone can tell me a good battery to run it off of or maybe it would be better to run it off my main battery.
Thanks in Advance
