I am subscribing to /diagnostics
topic, to which all my nodes are publishing their outputs. In my source file, I have created a map of all the node names as follows -
std::map<string, int> TextCode;
TextCode = {{"Camera_node1", 1}, {"LIDAR_node2", 2}};
I have prepopulated the map with few nodes (as above). I have a callback function, in which I publish the node name whenever the level of operation is ERROR
void diagnosticCallback(const diagnostic_msgs::DiagnosticArrayPtr &diags_msg)
int Maincode;
if (diags_msg->status[0].level == diagnostic_msgs::DiagnosticStatus::ERROR)
Maincode = TextCode[diags_msg->status[0].name];
ROS_INFO_STREAM("Error occured : " << Maincode);
else if (diags_msg->status[0].level == diagnostic_msgs::DiagnosticStatus::OK)
ROS_INFO_STREAM("No error");
I want to check the node names every time we receive ERROR
and then check all the elements of my map TextCode
, if the name is present. If not then add the name as the next element in the map. How should I proceed with that?
Note - Diagnostics_msgs - http://docs.ros.org/api/diagnostic_msgs/html/msg/DiagnosticStatus.html
Originally posted by robo_ninja on ROS Answers with karma: 55 on 2017-12-04
