I asked a question similar to this earlier, but I believe I have a new problem. I've been working on figuring out the inverse kinematics given an x,y,z coordinate. I've adopted the Jacobian method, taking the derivative of the forward kinematics equations with respect to their angles and input it into the Jacobian. I then take the inverse of it and multiply it by a step towards the goal distance. For more details, look at http://www.seas.upenn.edu/~meam520/notes02/IntroRobotKinematics5.pdf page 21 onwards.
For a better picture, below is something:
Below is the code for my MATLAB script, which runs flawlessly and gives a solution in under 2 seconds:
ycurrent = 0; %Not using this
xcurrent = 0; %Starting position (x)
zcurrent = 0; %Starting position (y)
xGoal = .5; %Goal x/z values of (1, 1)
zGoal = .5;
theta1 = 0.1; %Angle of first DOF
theta2 = 0.1; %Angle of second DOF
theta3 = 0.1; %Angle of third DOF
xchange = xcurrent - xGoal %Current distance from goal
zchange = zcurrent - zGoal
%Length of segment 1: 0.37, segment 2:0.374, segment 3:0.2295
while ((xchange > .02 || xchange < -.02) || (zchange < -.02 || zchange > .02))
in1 = 0.370*cos(theta1); %These equations are stated in the link provided
in2 = 0.374*cos(theta1+theta2);
in3 = 0.2295*cos(theta1+theta2+theta3);
in4 = -0.370*sin(theta1);
in5 = -0.374*sin(theta1+theta2);
in6 = -0.2295*sin(theta1+theta2+theta3);
jacob = [in1+in2+in3, in2+in3, in3; in4+in5+in6, in5+in6, in6; 1,1,1];
invJacob = inv(jacob);
xcurrent = .3708 * sin(theta1) + .374 * sin(theta1+theta2) + .229 * sin(theta1+theta2+theta3)
zcurrent = .3708 * cos(theta1) + .374 * cos(theta1+theta2) + .229 * cos(theta1+theta2+theta3)
xIncrement = (xGoal - xcurrent)/100;
zIncrement = (zGoal - zcurrent)/100;
increMatrix = [xcurrent; zcurrent; 1]; %dx/dz/phi
change = invJacob * increMatrix; %dtheta1/dtheta2/dtheta3
theta1 = theta1 + change(1)
theta2 = theta2 + change(2)
theta3 = theta3 + change(3)
end
Below is my Python code, which goes into an infinite loop and gives no results. I've looked over the differences between it and the MATLAB code, and they look the exact same to me. I have no clue what is wrong. I would be forever grateful if somebody could take a look and point it out.
def sendArm(xGoal, yGoal, zGoal, right, lj):
ycurrent = xcurrent = zcurrent = 0
theta1 = 0.1
theta2 = 0.1
theta3 = 0.1
xcurrent, zcurrent = forwardKinematics(theta1, theta2, theta3)
while ((xchange > 0.05 or xchange < -0.05) or (zchange < -0.05 or zchange > 0.05)):
in1 = 0.370*math.cos(theta1) #Equations in1-6 are in the pdf I linked to you (inv kinematics section)
in2 = 0.374*math.cos(theta1+theta2)
in3 = 0.2295*math.cos(theta1+theta2+theta3)
in4 = -0.370*math.sin(theta1)
in5 = -0.374*math.sin(theta1+theta2)
in6 = -0.2295*math.sin(theta1+theta2+theta3)
jacob = matrix([[in1+in2+in3,in2+in3,in3],[in4+in5+in6,in5+in6,in6], [1,1,1]]) #Jacobian
invJacob = inv(jacob) #inverse of jacobian
xIncrement = (xGoal - xcurrent)/100 #dx increment
zIncrement = (zGoal - zcurrent)/100 #dz increment
increMatrix = matrix([[xIncrement], [zIncrement], [1]])
change = invJacob*increMatrix #multiplying both matrixes
theta1 = theta1 + change.item(0)
theta2 = theta2 + change.item(1)
theta3 = theta3 + change.item(2)
print "Xchange: %f ZChange: %f" % (xchange, zchange)
print "Goals %f %f %f" % (theta1, theta2, theta3)
right.set_joint_positions(theta1) #First pitch joint
right.set_joint_positions(theta2) #Second pitch
right.set_joint_positions(theta3) #Third Pitch joint
def forwardKinematics(theta1, theta2, theta3):
xcurrent = .3708 * math.sin(theta1) + .374 * math.sin(theta1+theta2) + .229 * math.sin(theta1+theta2+theta3)
zcurrent = .3708 * math.cos(theta1) + .374 * math.cos(theta1+theta2) + .229 * math.cos(theta1+theta2+theta3)
return xcurrent, zcurrent
