http://wiki.ros.org/pid
When I start/restart a PID node, the setpoint is always set to 0, but the actual current position may be something else. If I want to make sure that my robot doesn't move back to 0 every time I restart the PID node, how would I give it an initial value, read from a node publishing the robots actual position? (the position publisher is on an arduino)
In other words, what I want to do is set the setpoint = current_position whenever the PID node starts/restarts.
These are the steps to reproduce the issue:
  1. Start the Arduino (publishes actual position)
  2. Move the robot manually to 5 meters (the arduino now publishes the current position as +5 meters)
  3. Start the PID; the PID is automatically set to "enabled" with a set position of "0"
  4. Robot moves to 0 without explicit instruction to do so
So I think the best solution would be to have an parameter to disable the PID on start. That way whatever logic enables it can make sure that the set-point is set correctly.
Originally posted by waspinator on ROS Answers with karma: 122 on 2017-11-29
Try setting the Arduino publisher to "latch." Then the PID node should hear the most recently-published setpoint when it subscribes. (Hopefully the Arduino API allows latching...)
Edit: the latest commit will wait for you. bitbucket.org/pid
Originally posted by AndyZe with karma: 2331 on 2017-11-29
Comment by waspinator on 2017-12-05:
the arduino does't issue the setpoint, it's set by a node running on the main system. The arduino does publish the current position of the robot though. I updated the question to be more specific.
Comment by AndyZe on 2017-12-05:
Ok. To be clear, if you clone the latest commit, you shouldn't have this problem anymore.
