Hi everyone,
I am trying to have a simple RQT template to use in the future whenever I need to create a new GUI. The main idea of my minimal (not) working example (MNWE) is to have:
  • TemplatePlugin class that is exported as plugin for RQT;
  • TemplateWidget class that implements an RQT widget that is then included in TemplatePlugin.
This is a similar approach employed in rqt_multiplot where there's one main MultiplotPlugin that includes different widgets.
I'm able to compile my (MNWE) , but when I launch the gui I get the following error:
[ERROR] [1511538332.555287110]: Failed to load nodelet [rqt_template_plugin::TemplatePlugin_0] of type [rqt_template_plugin::TemplatePlugin]: Failed to load library /home/marco/catkin_ws/devel/lib//librqt_template_plugin.so. Make sure that you are calling the PLUGINLIB_EXPORT_CLASS macro in the library code, and that names are consistent between this macro and your XML. Error string: Could not load library (Poco exception = /home/marco/catkin_ws/devel/lib//librqt_template_plugin.so: undefined symbol: _ZN19rqt_template_plugin14TemplatePluginD1Ev)
RosPluginlibPluginProvider::load_explicit_type(rqt_template_plugin::TemplatePlugin) failed creating instance PluginManager._load_plugin() could not load plugin "rqt_template_plugin::TemplatePlugin": RosPluginlibPluginProvider.load() could not load plugin "rqt_template_plugin::TemplatePlugin"
Even though the error suggests that I don't have the macro "PLUGINLIB_EXPORT_CLASS", it is actually present in my cpp file: PLUGINLIB_EXPORT_CLASS. So I guess I am not linking the plugin at compile time correctly and then having issue at run time. I tried the solution proposed in this other thread question/215487, but adding "set(CMAKE_AUTOMOC ON)" to make CMakeLists.txt file prevents me compiling the whole package.
Update of 27/11/2017
Running the command
for f in $(find ~/catkin_ws -name "*.so"); do echo $f; objdump -TC $f | grep _ZN19rqt_template_plugin14TemplatePluginD1Ev; done
the symbol "_ZN19rqt_template_plugin14TemplatePluginD1Ev" is not found at all. Whereas if I run the command
for f in $(find ~/catkin_ws -name "*.so"); do echo $f; objdump -TC $f | grep rqt_template_plugin; done
Then I obtain:
/home/marco/catkin_ws/devel/lib/librqt_template_plugin.so
/home/marco/catkin_ws/devel/lib/librqt_template_plugin.so:     file format elf64-x86-64
0000000000000000      D  *UND*  0000000000000000
rqt_template_plugin::TemplatePlugin::~TemplatePlugin()
0000000000000000      D  *UND*  0000000000000000              non-virtual thunk to
** End Update **
I was wondering if anyone could give me a hint about what I should try next.
Thanks a lot,
Marco.
Originally posted by Femer on ROS Answers with karma: 253 on 2017-11-24
Comment by Ruben Alves on 2017-11-24:
Not an answer but maybe helps. You can see if the symbol exists in any library on your catkin_ws with:
If is defined, it will be printed after the name of the .so
If you see that the symbol is defined, then is just because it's not being loaded at runtime.
See if the path to the library is on your LD_LIBRARY_PATH with: env | grep LD_LIBRARY_PATH
Comment by Femer on 2017-11-27:
Hi Ruben, thanks for your comment! With your first command the symbol was not found at all. Instead if I grep rqt_template then I get the result I just pasted in the updated question ... any idea?
Hi @Femer !
The problem is that you missed the implementation of the destructor. You can solve just by defining TemplatePlugin::~TemplatePlugin(){} on your TemplatePlugin.cpp.
I've discovered this by running c++filt _ZN19rqt_template_plugin14TemplatePluginD1Ev that give us the following output: rqt_template_plugin::TemplatePlugin::~TemplatePlugin().
I've created a video (https://youtu.be/4xZKflNlJho) that shows that this was the only problem.
Ruben.
Originally posted by Ruben Alves with karma: 1038 on 2017-11-28
Comment by Femer on 2017-11-28:
Awesome! That was it! Thanks for spotting this!
