Hi all,
I used something similar to the following code according to this tutorial to spawn a collision object in the world:
moveit_msgs::CollisionObject collision_object;
collision_object.header.frame_id = group.getPlanningFrame();
/* The id of the object is used to identify it. */
collision_object.id = "box1";
/* Define a box to add to the world. */
shape_msgs::SolidPrimitive primitive;
primitive.type = primitive.BOX;
primitive.dimensions.resize(3);
primitive.dimensions[0] = 0.4;
primitive.dimensions[1] = 0.1;
primitive.dimensions[2] = 0.4;
/* A pose for the box (specified relative to frame_id) */
geometry_msgs::Pose box_pose;
box_pose.orientation.w = 1.0;
box_pose.position.x =  0.6;
box_pose.position.y = -0.4;
box_pose.position.z =  1.2;
collision_object.primitives.push_back(primitive);
collision_object.primitive_poses.push_back(box_pose);
collision_object.operation = collision_object.ADD;
std::vector<moveit_msgs::CollisionObject> collision_objects;
collision_objects.push_back(collision_object);
I have 2 questions now:
  1. Is there a way to change the position of the collision object directly?
  2. Can the position be changed when the object is attached to a robot?
My first idea would have been to remove the object and add it again in the scene, but that is quite lengthy though. Would be nice if someone can tell me if there is a shorter way to do this :) Thank you in advance!
Originally posted by rfn123 on ROS Answers with karma: 146 on 2017-11-17
Hi!
  1. It is possible.
  2. Not sure. If the object is attached to the robot through the URDF then is not possible. If you attach the object using moveit_msgs/AttachedCollisionObject.h it will move with the robot until you detach it.
Check this code I implemented, it uses the MOVE operation and works fine. I hope it will be helpful.
It listens to three different transformations published by aruco_ros package and then it updates the position of the objects in the planning scene. The robot avoids collision with these objects. The moveit_msgs::CollisionObject bin is reused since the three objects have the same mesh.
Nicolas.
#include "geometric_shapes/shapes.h"
#include "geometric_shapes/mesh_operations.h"
#include "geometric_shapes/shape_operations.h"
#include <moveit/planning_scene_interface/planning_scene_interface.h>
#include <moveit_msgs/CollisionObject.h>
#include <tf/transform_listener.h>
int main(int argc, char** argv){
ros::init(argc, argv, "bins_tracker");
ros::NodeHandle node;
tf::TransformListener listener; //tf listener & transformations
tf::StampedTransform t_bin1;
tf::StampedTransform t_bin2;
tf::StampedTransform t_bin3;
std::vector<moveit_msgs::CollisionObject> collision_objects; //vector of objects
std::vector<std::string> object_ids; //vector of strings (names of objects)
object_ids.push_back("Bin1");
object_ids.push_back("Bin2");
object_ids.push_back("Bin3");
moveit::planning_interface::PlanningSceneInterface planning_scene_interface; //planning interface
moveit_msgs::CollisionObject bin; //Create an object msg
shapes::Mesh* m = shapes::createMeshFromResource("package://motoman_sda10f_support/meshes/bin.stl"); //find mesh
shape_msgs::Mesh mesh; //create a mesh msg
shapes::ShapeMsg mesh_msg; //create a shape msg
shapes::constructMsgFromShape(m,mesh_msg); //convert shape into a shape msg
ros::Duration(0.5).sleep();
mesh = boost::get<shape_msgs::Mesh>(mesh_msg); // shape msg is assigned to mesh msg
bin.header.frame_id = "torso_base_link"; //"father frame"
bin.meshes.resize(1); //scale
bin.meshes[0]=mesh; //mesh
bin.mesh_poses.resize(1); //vector resize
bin.mesh_poses[0].position.x = 0; //pose
bin.mesh_poses[0].position.y = 0;
bin.mesh_poses[0].position.z = 0;
bin.mesh_poses[0].orientation.w= 1.0;
bin.mesh_poses[0].orientation.x= 0;
bin.mesh_poses[0].orientation.y= 0;
bin.mesh_poses[0].orientation.z= 0;
bin.operation = bin.ADD; //add object to collitions
bin.id =object_ids[0]; //rename object
collision_objects.push_back(bin); //you can insert different objects using a vector of collition objects
bin.id=object_ids[1]; //rename object and reuse bin msg struture
collision_objects.push_back(bin); //add object to vector
bin.id=object_ids[2];//rename object and reuse bin msg struture
planning_scene_interface.addCollisionObjects(collision_objects); //add objects to planning interface
bin.meshes.clear(); //Clear mesh required for MOVE operation (Only to avoid a warning)
bin.operation = bin.MOVE; //change operation to MOVE
while (node.ok()){
    //Listen to tfs
    try{
        listener.lookupTransform("torso_base_link", "bin1", ros::Time(0), t_bin1);
        catch (tf::TransformException ex){
        ROS_WARN("%s",ex.what());
    try{
        listener.lookupTransform("torso_base_link", "bin2", ros::Time(0), t_bin2);
    try{
        listener.lookupTransform("torso_base_link", "bin3", ros::Time(0), t_bin3);
    collision_objects.clear(); //clear previous data in the vector
    bin.id = object_ids[0]; //bin 1
    bin.mesh_poses[0].position.x = t_bin1.getOrigin().x(); //set pose
    bin.mesh_poses[0].position.y = t_bin1.getOrigin().y();
    bin.mesh_poses[0].position.z = t_bin1.getOrigin().z();
    bin.mesh_poses[0].orientation.w= t_bin1.getRotation().w();
    bin.mesh_poses[0].orientation.x= t_bin1.getRotation().x();
    bin.mesh_poses[0].orientation.y= t_bin1.getRotation().y();
    bin.mesh_poses[0].orientation.z= t_bin1.getRotation().z();
    collision_objects.push_back(bin); // add to vector
    bin.id = object_ids[1]; //rename
    bin.mesh_poses[0].position.x = t_bin2.getOrigin().x(); //set pose
    bin.mesh_poses[0].position.y = t_bin2.getOrigin().y();
    bin.mesh_poses[0].position.z = t_bin2.getOrigin().z();
    bin.mesh_poses[0].orientation.w= t_bin2.getRotation().w();
    bin.mesh_poses[0].orientation.x= t_bin2.getRotation().x();
    bin.mesh_poses[0].orientation.y= t_bin2.getRotation().y();
    bin.mesh_poses[0].orientation.z= t_bin2.getRotation().z();
    collision_objects.push_back(bin); //add to vector
    bin.id = object_ids[2]; //rename
    bin.mesh_poses[0].position.x = t_bin3.getOrigin().x(); //add vector
    bin.mesh_poses[0].position.y = t_bin3.getOrigin().y();
    bin.mesh_poses[0].position.z = t_bin3.getOrigin().z();
    bin.mesh_poses[0].orientation.w= t_bin3.getRotation().w();
    bin.mesh_poses[0].orientation.x= t_bin3.getRotation().x();
    bin.mesh_poses[0].orientation.y= t_bin3.getRotation().y();
    bin.mesh_poses[0].orientation.z= t_bin3.getRotation().z();
    planning_scene_interface.applyCollisionObjects(collision_objects); //apply changes to planning interface
    ros::Duration(0.5).sleep(); //ZzZzZ
planning_scene_interface.removeCollisionObjects(object_ids); //delete objects from planning interface*/
ros::shutdown(); //turn off
return 0;
Originally posted by CTAI-PUJ with karma: 26 on 2018-09-18
