Hi,
Im wroking on a Robot that do the mapping, I'm using UltraSonic Sensors, IMU and Hall Sensors From the BLDC Motor, Arduino Mega 2560 and ROS Kinetic.
The next step is the obstacle avoidance. So the question is: How can I do obstacle avoidance using Lasersan data ???
Originally posted by أسامة الادريسي on ROS Answers with karma: 37 on 2017-11-16
Comment by gvdhoorn on 2017-11-17:\
one important requirement: do you have a laser scanner or similar device? Ultrasonic sensors != laser scanners.
Comment by أسامة الادريسي on 2017-11-17:
I have 3 ultrasonic sensors, I converted it to a Laserscan
Comment by Syrine on 2019-06-26:
Hi, I know the post is old but i have the same problem, did you manage to avoid obstacles using ultrasound sensors? thanks
The tutorials on Navigation stack would be the right place to start (http://wiki.ros.org/navigation). The turtlebot implementation is a good example to see gmapping and amcl in action (https://github.com/turtlebot/turtlebot_apps/tree/indigo/turtlebot_navigation). Just remember that once you create a map, the path generation in that map is independent of the sensors.
Originally posted by ninja777 with karma: 101 on 2017-11-16
