HI everybody, I'm studying ROS, and I have a problem. I want to add my message to Arduino sketch, I successfully compiled the Arduino sketch in catkin workspace, but when I tried to add my meessage header file I obtain error: "NO such file or catalog" (massage successfully compiled in "devel/include/..."). Can anyone help me add a message ?
Error:
[ 91%] Building CXX object CMakeFiles/hello.dir/chatter.cpp.obj
/home/amrello/catkin_ws/src/arduino/firmware/chatter.cpp:4:27: fatal error: arduino/data1.h: No such file or catalog
 #include <arduino/data1.h>
compilation terminated.
chatter.cpp (simplest publisher):
 #include <ros.h>
 #include <std_msgs/String.h>
 #include <Arduino.h>
 ros::NodeHandle nh;
 std_msgs::String str_msg;
 ros::Publisher chatter("chatter", &str_msg);
 char hello[13] = "hello world!";
 void setup()
   nh.initNode();
   nh.advertise(chatter);
 void loop()
   str_msg.data = hello;
   chatter.publish( &str_msg );
   nh.spinOnce();
   delay(1000);
CMakeLists.txt (in src ):
include_directories(${ROS_LIB_DIR})
# Remove this if using an Arduino without native USB (eg, other than Leonardo)
#add_definitions(-DUSB_CON)
generate_arduino_firmware(hello
   SRCS chatter.cpp ${ROS_LIB_DIR}/time.cpp ${ROS_LIB_DIR}/time.cpp
   BOARD mega2560
   PORT /dev/ttyACM0
CMakeLists.txt:
project(arduino)
  rosserial_arduino
  rosserial_client
  roscpp
  std_msgs
  message_generation
add_message_files(
        FILES
        data1.msg
 generate_messages(
   DEPENDENCIES
   std_msgs
catkin_package(
CATKIN_DEPENDS message_runtime
include_directories(include
  ${catkin_INCLUDE_DIRS}
rosserial_generate_ros_lib(
  PACKAGE rosserial_arduino
  SCRIPT make_libraries.py
rosserial_configure_client(
  DIRECTORY firmware
  TOOLCHAIN_FILE ${ROSSERIAL_ARDUINO_TOOLCHAIN}
rosserial_add_client_target(firmware hello ALL)
rosserial_add_client_target(firmware hello-upload)
Originally posted by Amrello on ROS Answers with karma: 26 on 2017-11-15
Comment by jayess on 2017-11-15:
It would be helpful if you copy and pasted the code and the terminal output here.
Can you please post your CMakeLists.txt too?
Why do you have two different CMakeLists.txt?
Comment by Amrello on 2017-11-16:
From this tutorial http://wiki.ros.org/rosserial_arduino/Tutorials/CMake
Hi there! You have to rebuild your Arduino-ROS library in the same terminal that you source devel/setup.bash . Once you rebuild your Arduino library your messages should appear there :)
Originally posted by bpinaya with karma: 700 on 2017-11-15
Comment by Amrello on 2017-11-15:
I mean that I can compile sketch from catkin workspace, but dont know how to add custom message, when i tried to add msg data1.h i get error.
@Amrello: it would be helpful if you updated your question with what you've tried already (i.e., please post your source code)
