I am on ROS Kinetic and Ubuntu 16.04. When I call a catkin_make after cloning https://github.com/DLu/navigation_layers into my catkin_ws/src, I get the following error:
 +++ processing catkin package: 'range_sensor_layer'
-- ==> add_subdirectory(navigation_layers/range_sensor_layer)
CMake Error at /opt/ros/kinetic/share/costmap_2d/cmake/costmap_2dConfig.cmake:106 (message):
  Project 'costmap_2d' specifies '/usr/include/hdf5/openmpi' as an include
  dir, which is not found.  It does neither exist as an absolute directory
  nor in '/opt/ros/kinetic//usr/include/hdf5/openmpi'.  Ask the maintainer
  'David V.  Lu!! <[email protected]>, Michael Ferguson
  <[email protected]>' to fix it.
  /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:76 (find_package)
  navigation_layers/range_sensor_layer/CMakeLists.txt:4 (find_package)
costmap_2d wants to have a library in this dir /usr/include/hdf5/openmpi, which does not exist. However, /usr/include/hdf5/ DOES exist, so does /usr/include/openmpi
Why does my ROS installation seem to differ from what costmap_2d expects? More important: How to fix this?
Originally posted by Chrizzl on ROS Answers with karma: 48 on 2017-11-15
Comment by ahendrix on 2017-11-15:
I've seen issues like this happen occasionally if the include directory exists but is then removed; cmake caches the old path and then complains when it ceases to exist. You may want to try cleaning your workspace and rebuilding.
Comment by gvdhoorn on 2017-11-15:
In addition to what @ahendrix writes: hdf5 is not a dependency of range_sensor_layer, nor (but I can't be certain) of one of its immediate dependencies.
It would appear the OpenMPI is then a dependency of hdf5, which does something strange (the include path doesn't make sense).
It could be that hdf5 comes in via the pcl dependency of costmap_2d (here).
Do you have a from-source build of PCL?
Comment by Chrizzl on 2017-11-15:
@gvdhoorn I wrote an answer, maybe you can shed some light on the things that are still unclear for me. That way we might help future readers ;)
@ahendrix Thanks for the suggestion but I already tried that before posting my qeustion here, it did nothing
Comment by Felix Messmer on 2020-12-01:
although this question is quite old, the problem just recently popped up again: https://github.com/ros-planning/navigation/issues/1058
any ideas how to properly solve this?
I suspect this https://github.com/shogun-toolbox/shogun/issues/2626 has something to do with the issue I was facing.
sudo apt-get install libhdf5-openmpi-dev
solved my immediate issues. However: here I got new problems about not finding libvtkproj4-6.2.so. I think there were some bugs around that as well, but the issues differ slightly: https://github.com/PointCloudLibrary/pcl/issues/1594 https://bugs.launchpad.net/ubuntu/+source/vtk6/+bug/1573234
This issue could be fixed by
sudo apt-get install libvtkproj-dev
But I knew I was on the wrong path trying to fix the symptoms of a problem instead of the source. The new issue that appeared was that catkin could not find costmap_2d anymore.
So: I fixed all my problems with
sudo apt-get update
sudo apt-get install ros-kinetic-navigation
I don't know if the first 2 calls are completely overwritten by the apt-get update and reinstall of the navigation package (don't know if they had an effect in solving my problem). All I know is: it works now.
Originally posted by Chrizzl with karma: 48 on 2017-11-15
