fatal: unable to access 'https://github.com/pirobot/rbx1.git/': Failed to connect to 127.0.0.1 port 35173: Connection refused
Originally posted by [email protected] on ROS Answers with karma: 11 on 2017-11-15
Comment by ahendrix on 2017-11-15:
That looks like a local IP address and port number; not the public address for github. Do you have a proxy or something else installed that might be interfering with your network connectivity?
Comment by [email protected] on 2017-11-15:
How can I check if I have a proxy?Thank you|
The error appears when I git clone,show as follows:
$ git clone https://github.com/pirobot/rbx1.git
Cloning into 'rbx1'...
I can successfully view https://github.com/pirobot/rbx1.git in the browser,and I can successfully ping 127.0.0.1
Comment by l4ncelot on 2017-11-15:
127.0.0.1 is address of your own computer.
Comment by clyde on 2017-11-15:
Make sure you can ping github.com
. If you can't, there are lots of networking help sites. This might help: https://unix.stackexchange.com/questions/109404/why-cant-i-ping-google
I can ping github.com. The result is shown below:
PING github.com (192.30.255.112) 56(84) bytes of data.
64 bytes from lb-192-30-255-112-sea.github.com (192.30.255.112): icmp_seq=1 ttl=128 time=348 ms
64 bytes from lb-192-30-255-112-sea.github.com (192.30.255.112): icmp_seq=2 ttl=128 time=316 ms
64
