I am setting a few parameters in my launch file. I can verify my parameters have been set correctly based on the terminal output. However, when roslaunch attempts to start the node, it ignores the set parameters. How do I fix this? kindly see below for details.
The parameters are correct and everything works when I use rosrun.
I am using a Lenovo laptop (W530) with Ubuntu 14.04. ROS distribution is Indigo which I installed with apt-get.
the launch file looks like this:
<launch>
<!--define the serial port for the PC to LMS comm in parameter server-->
<param
    name="sicklms/port"
    value="/dev/ttyUSB0">
</param>
<!--define the lms comm baud rate in parameter server-->
<param
    name="sicklms/baud"
    value="500000">
</param>
<!--launch the sicktoolbox_wrapper node. -->
<node
    pkg="sicktoolbox_wrapper"
    type="sicklms"
    name="sick_lms_scan_publisher"
    output="screen">
</node>
</launch>
The terminal message when I run the roslauch command looks like this:
constructor@constructor-pc:~/Desktop/workspace$ roslaunch j_robot_state_publisher jimmy_state_publisher.launch
... logging to /home/constructor/.ros/log/4d83f6e0-c8c8-11e7-9df6-e09d3128cfa4/roslaunch-constructor-pc-11263.log
Press Ctrl-C to interrupt
started roslaunch server http://constructor-pc:38491/
SUMMARY
PARAMETERS
* /robot_description: <?xml version="1....
* /rosdistro: indigo
* /rosversion: 1.11.21
* /sicklms/baud: 500000
* /sicklms/port: /dev/ttyUSB0
NODES
jimmy_state_publisher (j_robot_state_publisher/jimmy_state_publisher)
node_publishing_enc_data (j_lms_enc_pos_publisher/publish_lms_enc_pos)
robot_state_publisher (robot_state_publisher/robot_state_publisher)
rviz (rviz/rviz)
sick_lms_scan_publisher (sicktoolbox_wrapper/sicklms)
core service [/rosout] found
process[node_publishing_enc_data-1]: started with pid [11282]
 process[robot_state_publisher-2]: started with pid [11283]
 process[jimmy_state_publisher-3]: started with pid [11284]
 process[sick_lms_scan_publisher-4]: started with pid [11292]
 process[rviz-5]: started with pid [11308]
*** Attempting to initialize the Sick LMS...
Attempting to open device @ /dev/lms200
ERROR: I/O exception - SickLMS2xx::_setupConnection: - Unable to open serial port
[ERROR] [1510615504.630421790]: Initialize failed! are you using the correct device path?
[ INFO] [1510615504.715419546]: rviz version 1.11.18
[ INFO] [1510615504.715525284]: compiled against Qt version 4.8.6
[ INFO] [1510615504.715558080]: compiled against OGRE version 1.8.1 (Byatis)
[sick_lms_scan_publisher-4] process has died [pid 11292, exit code 2, cmd /home/constructor/Desktop    /workspace/devel/lib/sicktoolbox_wrapper/sicklms __name:=sick_lms_scan_publisher __log:=/home/constructor/.ros/log/4d83f6e0-c8c8-11e7-9df6-e09d3128cfa4/sick_lms_scan_publisher-4.log].log file: /home/constructor/.ros/log/4d83f6e0-c8c8-11e7-9df6-e09d3128cfa4/sick_lms_scan_publisher-4*.log
[ INFO] [1510615505.088206168]: Stereo is NOT SUPPORTED
[ INFO] [1510615505.088408404]: OpenGl version: 4.4 (GLSL 4.4).
You can see that the sicklms/port: /dev/ttyUSB0 is set correctly, and just a few lines down the code tries to use the wrong parameter (Attempting to open device @ /dev/lms200)
I tried:
  1. starting up roscore, and then manually setting the parameter using rosparam set sicklms/port /dev/ttyUSB0. Then I confirmed it using sickparam get /sicklms/port and it is indeed /dev/ttyUSB0. Then I try roslauch again, and I get the same exact error.
  2. I tried to start the node manually using rosrun sicktoolbox_wrapper sicklms and the node starts up fine.
  3. Originally the launch file code was kept in a package that was not the sicktoolbox_wrapper. I tried to move all the code in the launch file related to sicktoolbox_wrapper from that launch file into a launch file in the sicktoolbox_wrapper package. I thought that this might do something. it did nothing.
Any ideas? I am really hoping to start this node using roslaunch... I am not a programmer and my code is already ugly.. I don't want to revert to using the working line rosrun sicktoolbox_wrapper sicklms using expect. if you could suggest what is going south I would greatly appreciate it.
Originally posted by BuilderMike on ROS Answers with karma: 247 on 2017-11-13
Comment by jayess on 2017-11-13:
Can you please copy and paste the terminal output to your question? Images aren't searchable and pastebins can disappear.
It looks like setting the parameters in the wrong namespace. Since the driver is looking for the parameters in it's private namespace, they need to be in the namespace of the node name (sick_lms_scan_publisher).
Roslaunch can help you avoid errors like this by doing the namespacing automatically, if you nest the param tags inside the node tag in your launch file:
<launch>
  <node
      type="sicklms"
      output="screen">
    <param name="port" value="/dev/ttyUSB0">
    <param name="baud" value="500000"/>
  </node>
</launch>
You can also do this with param tags outside of the node tag, but it's more error-prone because you're duplicating the node name in many places:
<launch>
    <param
        name="sick_lms_scan_publisher/port"
    </param>
    <param
        name="sick_lms_scan_publisher/baud"
        value="500000">
    </param>
    <node
        type="sicklms"
        output="screen">
    </node>
</launch>
Originally posted by ahendrix with karma: 47576 on 2017-11-13
Comment by BuilderMike on 2017-11-14:
@ahendrix thank you very much!! worked like a charm. Thank you for your time and expertise.
