Hi, I'm compiling ROS Kinetic from source for the Raspberry Pi 3. Recently I started getting a lot of these warnings:
Scanning dependencies of target rosout
[ 50%] Building CXX object CMakeFiles/rosout.dir/rosout.cpp.o
[100%] Linking CXX executable /home/pi/ros_catkin_ws/devel_isolated/rosout/lib/rosout/rosout
/usr/bin/ld: warning: libboost_system.so.1.54.0, needed by /usr/lib/gcc/arm-linux-gnueabihf/4.9/../../../arm-linux-gnueabihf/libconsole_bridge.so, may conflict with libboost_system.so.1.55.0
/usr/bin/ld: warning: libboost_thread.so.1.54.0, needed by /usr/lib/gcc/arm-linux-gnueabihf/4.9/../../../arm-linux-gnueabihf/libconsole_bridge.so, may conflict with libboost_thread.so.1.55.0
[100%] Built target rosout
These don't seem to affect anything, but I'd like to understand more about why these started appearing.
Edit: I have headers for 1.55.0 installed via apt, and libraries for 1.54.0 and 1.55.0:
pi@raspberry:~$ find / -name libboost_system.so* | less
/usr/lib/arm-linux-gnueabihf/libboost_system.so.1.54.0
/usr/lib/arm-linux-gnueabihf/libboost_system.so.1.55.0
pi@raspberry:~$ ls -l /usr/lib/arm-linux-gnueabihf/libboost_system.so
lrwxrwxrwx 1 root root 25 Sep 24  2014 /usr/lib/arm-linux-gnueabihf/libboost_system.so -> libboost_system.so.1.55.0
Originally posted by clyde on ROS Answers with karma: 1247 on 2017-10-31
Comment by gvdhoorn on 2017-11-04:
Do you have multiple versions of Boost installed?
Comment by clyde on 2017-11-05:
1.55.0 and 1.54.0, see edits
Comment by clyde on 2017-11-06:
Hmmm, looking at /var/log/apt/history.log, it appears that both versions were installed by rosdep. First "apt-get install -y libboost-all-dev", which pulled in all of 1.55, then "apt-get install -y libconsole-bridge-dev" which pulled in 2 libraries from 1.54.
Multiple boost versions on the same machine can work, but typically only if you keep them strictly separate. See #q274016 for another question about that and some thoughts.
Did you build the 'other Boost' from sources? It can't have just "turned up" on its own.
Originally posted by gvdhoorn with karma: 86574 on 2017-11-05
