Hello,
I'm are trying to use orientation constraints to keep the end effector in the same orientation as the current pose, however I can't get it to work. It always gives the following error:
Orientation constraint violated for link 'ee_link'.
How is this possible? Because I set the constraint orientation from the current pose, and it already errors in the current pose.
I'm setting the orientation constraint as follows:
this->ocm.link_name = "ee_link";
this->ocm.header.frame_id = "base_link"
this->ocm.weight = 1.0;
this->ocm.orientation = this->move_group.getCurrentPose().pose.orientation;
this->ocm.absolute_x_axis_tolerance = 0.1;
this->ocm.absolute_y_axis_tolerance = 0.1;
this->ocm.absolute_z_axis_tolerance = 2.0 * 3.14;
this->constraints.orientation_constraints.push_back(this->ocm);
this->move_group.setPathConstraints(this->constraints);
Our goal is to keep the end effector up, so it won't drop the object (a plant) the end effector is holding. I want to restrict the orientation, so it may only use yaw to rotate in it's path.
Maybe something is wrong with our tf tree?:
image description
Thanks in advance.
Originally posted by jeffreyp23 on ROS Answers with karma: 13 on 2017-10-11
this->ocm.header.frame_id = "base_link";
Are you sure getCurrentPose returns the pose in "base_link" and your current end-effector is "ee_link"? Try always to keep frame_ids and coordinates together and if you specify a hard-coded link name in one place, do the same for the rest of the code:
auto current_pose= this->move_group.getCurrentPose(this->ocm.link_name);
this->ocm.header.frame_id = current_pose.header.frame_id;
this->ocm.orientation = current_pose.pose.orientation;
It's hard to debug this further without more information on how you trigger the error.
Originally posted by v4hn with karma: 2950 on 2017-10-11
