I'm using a Fanuc M10iA robot from the ROS industrial package and I would like to generate a trajectory for this robot from a cartesian path (i.e. a list of cartesian positions and velocities).
Currently I use moveIt! and move_group->ComputeCartesianPath() to generate the robot trajectory. The robot moves but I don't know how to specify the velocities for the waypoints.
I want to move the robot with a given cartesian velocity and change this velocity in any point in the trajectory. How can I do this with ROS?
This is the code that i use to move the robot with MoveIt: (example package: https://gitlab.com/InstitutMaupertuis/fanuc_motion/tree/ros_answer_question)
#include <vector>
#include <ros/ros.h>
#include <eigen_conversions/eigen_msg.h>
#include <moveit/move_group_interface/move_group_interface.h>
#include <moveit_msgs/ExecuteKnownTrajectory.h>
  ros::init(argc, argv, "robot_trajectory");
  ros::NodeHandle node;
  ros::AsyncSpinner spinner(1);
  spinner.start();
  moveit::planning_interface::MoveGroupInterface group("manipulator");
  group.setPoseReferenceFrame("/base");
  group.setPlanningTime(1);
  // Create a trajectory (vector of Eigen poses)
  std::vector<Eigen::Affine3d, Eigen::aligned_allocator<Eigen::Affine3d> > way_points_vector;
  Eigen::Affine3d pose (Eigen::Affine3d::Identity());
  // Square belonging to XY plane
  pose.linear() <<
      1, 0, 0,
      0,-1, 0,
      0, 0, -1;
  pose.translation() << 0.8, 0.1, -0.1;
  way_points_vector.push_back(pose);
  pose.translation() << 1.0, 0.1, -0.1;
  pose.translation() << 1.0, 0.3, -0.1;
  pose.translation() << 0.8, 0.3, -0.1;
  way_points_vector.push_back(way_points_vector[0]);
  // Copy the vector of Eigen poses into a vector of ROS poses
  std::vector<geometry_msgs::Pose> way_points_msg;
  way_points_msg.resize(way_points_vector.size());
  for (size_t i = 0; i < way_points_msg.size(); i++)
    tf::poseEigenToMsg(way_points_vector[i], way_points_msg[i]);
  moveit_msgs::RobotTrajectory robot_trajectory;
  group.computeCartesianPath(way_points_msg, 0.05, 15, robot_trajectory);
  // Execute trajectory
  ros::ServiceClient executeKnownTrajectoryServiceClient = node.serviceClient<moveit_msgs::ExecuteKnownTrajectory>(
      "/execute_kinematic_path");
  moveit_msgs::ExecuteKnownTrajectory srv;
  srv.request.wait_for_execution = true;
  srv.request.trajectory = robot_trajectory;
  executeKnownTrajectoryServiceClient.call(srv);
  ros::waitForShutdown();
  spinner.stop();
   return 0;
Originally posted by AndresCampos on ROS Answers with karma: 21 on 2017-10-06
Comment by sharath on 2018-05-22:
Hi, I was looking for something similar to what you have asked for controlling the cartesian velocity of the waypoints. I searched but it seems its not yet done. I want to know if you were able to solve it?
MoveIt currently does not provide a method to request specific end-effector velocities.
We would welcome such an addition and it is clearly feasible. You can generate a valid time-parameterization for your cartesian trajectory using the moveit_core/trajectory_processing module. These methods generate velocities according to the maxima specified for each joint. If you want to attain a constant end-effector velocity you can rescale the timing relative to the slowest segment.
Originally posted by v4hn with karma: 2950 on 2017-10-10
Comment by kwh5484 on 2019-07-11:
Is there still interest in adding this to the MoveIt source code? If so, how you would like this functionality to be added to the overall MoveIt architecture? I've added a function to moveit_core/trajectory_processing/iterative_time_parameterization.cpp that rescales the timing based on a desired cartesian velocity for a specified end effector link. I was planning on using the MoveGroupInterface to pass the desired velocity and end effector link to the trajectory. I am not a MoveIt expert by any means, so if there is an alternate way you would like this implemented please let me know.
Alternatively, I could implement it separately from any time parameterization after the trajectory has been generated from the move_group.plan function call. This way, no existing data structures would need to be changed.
Comment by gvdhoorn on 2019-07-11:
Speaking for myself: yes, there would be interest.
but a comment on an already answered ROS Answers question is not necessarily the best place to discuss/announce this.
I would suggest to post an issue on the MoveIt issue tracker on github.
