I would like to emulate "design by contract" on the ROS node level by using diagnostics/self_test. To check a ROS nodes preconditions probably pretest() (self_test example) could be used. The ROS nodes postconditions could be checked with posttest() (self_test example). Could I trigger self_test test function execution when topics are published somehow?
Originally posted by thinwybk on ROS Answers with karma: 468 on 2017-10-02
Comment by gvdhoorn on 2017-10-02:
I guess this will depend on what it is you want to test / what is in your contract.
Comment by thinwybk on 2017-10-04:
The list of possible preconditions, postconditions and invariants which could be checked is long. The question is how checks could be executed in general. pretest() should work before ROS node startup (e.g. check if dependent on nodes are already running)...
... invariant checking could be done whenever a node received a topic message or a service request which could potentially change the node into an invalid state. The question is if it would be possible with self_test to use kind of callback function mechanism which would allow to execute checks then
Comment by gvdhoorn on 2017-10-04:
I don't think that self_test was intended to be used that way (it's more a "runtime testing" tool for diagnostic purposes), but perhaps it could be repurposed.
I know. I am just thinking about if self_test could be used to support design by contract, built-in-selftesting, etc.
self_test is not suitable to emulate "Design By Contract".
However self_test is not required to emulate DbC with self_test at all but would be overhead instead. It is sufficient to implement "assert" functions for parameter values, topics message values, service request/response message values and action goal/result/feedback topic message values and call them in corresponding "sections" of nodes. For "asserting" different alternatives come to mind: diagnostics status.summaryf(diagnostic_msgs::DiagnosticStatus::ERROR, "DbC violation" or logging rospy.logerr("DbC violation").
Originally posted by thinwybk with karma: 468 on 2017-10-15
