I'm a ROS beginner working on a custom controller for a UUV using Gazebo to simulate the environment and ROS to control everything. I'm using the uuv_simulator package, which does a lot of the heavy lifting for me. Currently, when certain conditions are met (i.e. the sonar reads a certain depth) I want the sub to stop moving. Fortunately, there's a service for that, /rexrov/hold_vehicle. Here's the results of a rosservice info request on it:
$ rosservice info /rexrov/hold_vehicle
Node:
/rexrov/plane_search_standard_controller
URI:
rosrpc://ncopeSub-VirtualBox:35331
Type: uuv_control_msgs/Hold
Args:
I've read all the tutorials I can find, and I'm working heavily with the services chapter of Jason O'Kane's book, but even when everything's how I think it should be I keep getting this error when I run catkin_make:
/home/catkin_ws/src/plane_search_standard/plane_detect_anomaly.cpp:4:35:
fatal error: uuv_control_msgs/Hold.h:
No such file or directory
compilation terminated.
plane_search_standard/CMakeFiles/subscribe_and_publish.dir/build.make:62:
recipe for target
'plane_search_standard/CMakeFiles/subscribe_and_publish.dir/plane_detect_anomaly.cpp.o'
failed make[2]: ***
[plane_search_standard/CMakeFiles/subscribe_and_publish.dir/plane_detect_anomaly.cpp.o]
Error 1 CMakeFiles/Makefile2:586:
recipe for target
'plane_search_standard/CMakeFiles/subscribe_and_publish.dir/all'
failed make[1]: ***
[plane_search_standard/CMakeFiles/subscribe_and_publish.dir/all]
Error 2 Makefile:138: recipe for
target 'all' failed make: *** [all]
Error 2 Invoking "make -j6 -l6" failed
Which seems to say that catkin_make doesn't know about the service header file for /rexrov/hold_vehicle. But by everything I've read, it should.
Here're my inclusions in the node file doing the service call:
#include <sstream>
#include <cmath>
#include <uuv_control_msgs/Hold.h>
#include "ros/ros.h"
#include "std_msgs/String.h"
#include "sensor_msgs/LaserScan.h"
Here's the line where I create the service client:
ros::ServiceClient stopSubCaller = n.serviceClient<uuv_control_msgs::Hold>("/rexrov/hold_vehicle");
Here're the lines where I actually call the service:
uuv_control_msgs::Hold::Request req;
uuv_control_msgs::Hold::Response resp;
bool success = stopSubCaller.call(req, resp);
And here's my messy CMakeLists.txt file:
project(plane_search_standard)
## Find catkin and any catkin packages
find_package(catkin REQUIRED COMPONENTS rospy roscpp std_msgs sensor_msgs uuv_control_msgs)
catkin_package()
catkin_install_python(PROGRAMS scripts/plane_search_standard_controller.py DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION})
install(DIRECTORY launch
        DESTINATION ${CATKIN_PACKAGE_SHARE_DESTINATION}
PATTERN "*~" EXCLUDE)
include_directories(include ${catkin_INCLUDE_DIRS})
add_executable(subscribe_and_publish plane_detect_anomaly.cpp)
target_link_libraries(subscribe_and_publish ${catkin_LIBRARIES})
add_dependencies(subscribe_and_publish ${catkin_EXPORTED_TARGETS})
Does anyone have an idea as to how I'm going wrong here? I'd really appreciate it - I'm about at my wit's end.
More info:
Running rossrv show uuv_control_msgs/Hold simply returns:
bool success
If I put uuv_control_msgs in the find_package command, catkin_make generates four errors like this, just with different endings where the _cpp is:
CMake Error at /home/ncope/catkin_ws/build/uuv_simulator/uuv_control/uuv_control_msgs/cmake/uuv_control_msgs-genmsg.cmake:321 (add_custom_target):
  add_custom_target cannot create target
  "uuv_control_msgs_generate_messages_cpp" because another target with the
  same name already exists.  The existing target is a custom target created
  in source directory "/home/ncope/catkin_ws/src/plane_search_standard".  See
  documentation for policy CMP0002 for more details.
  /opt/ros/kinetic/share/genmsg/cmake/genmsg-extras.cmake:307 (include)
  uuv_simulator/uuv_control/uuv_control_msgs/CMakeLists.txt:41 (generate_messages)
If I'm reading it right, it's saying genmsg already builds those files? And cutting genmsg of course cuts the generate_messages command entirely.
package.xml contents:
<?xml version="1.0"?>
<package>
  <name>plane_search_standard</name>
  <version>0.0.0</version>
  <description>The plane_search_standard package</description>
  <maintainer email="[email protected]">ncope</maintainer>
  <license>TODO</license>
  <buildtool_depend>catkin</buildtool_depend>
  <export>
  </export>
</package>
I now get an error that looks like this:
Could not find the required component 'uuv_control_msgs'. The following CMake error indicates that you either need to install the package with the same name or change your environment so that it can be found.
CMake Error at /opt/ros/kinetic/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
  Could not find a package configuration file provided by "uuv_control_msgs"
  with any of the following names:
    uuv_control_msgsConfig.cmake
    uuv_control_msgs-config.cmake
  Add the installation prefix of "uuv_control_msgs" to CMAKE_PREFIX_PATH or
  set "uuv_control_msgs_DIR" to a directory containing one of the above
  files.  If "uuv_control_msgs" provides a separate development package or
  SDK, be sure it has been installed.
  plane_search_standard/CMakeLists.txt:5 (find_package)
Originally posted by swordsgnat on ROS Answers with karma: 1 on 2017-09-27
What happens if you run
If you're getting a complaint that ROS can't find it or something along those lines then you may need to source your setup.bash.
Also, it looks like your CMakeLists.txt is missing uuv_control_msgs from the find_package command. Try adding it there and removing it from generate_messages and see what happens.
Edit:
As @gvdhoorn explained in the comments:
The missing uuv_control_msgs declaration (in the find_package(catkin ..)) is the problem. [...] uuv_control_msgs is only a DEPENDENCIES of your generate_messages(..) if you are actually building any msgs yourself (ie: in your own pkg). Afaict, you're not. You only depend on someone else's messages. In that case, you need to find that dependency when building, which is what the find_package(catkin REQUIRED COMPONENTS .. uuv_control_msgs ..) will do.
Edit 2:
Now, in your package.xml you need to add a dependency on uuv_control_msgs so add the following lines
<build_depend>uuv_control_msgs</build_depend>
<run_depend>uuv_control_msgs</run_depend>
Also, give the tutorials another go as a refresher for you. I still refer to them.
Originally posted by jayess with karma: 6155 on 2017-09-27
Comment by gvdhoorn on 2017-09-27:
The missing uuv_control_msgs declaration (in the find_package(catkin ..) is the problem.
@swordsgnat: uuv_control_msgs is only a DEPENDENCIES of your generate_messages(..) if you are actually building any msgs yourself (ie: in your own pkg). Afaict, you're not. You only depend ..
.. on someone else's messages. In that case, you need to find that dependency when building, which is what the find_package(catkin REQUIRED COMPONENTS .. uuv_control_msgs ..) will do.
Comment by jayess on 2017-09-27:
Thanks for the explanation @gvdhoorn. I should have included that.
Comment by swordsgnat on 2017-09-27:
Hi, thanks for the reply! There wasn't enough space in the comment here so I edited that additional information into the original question at the bottom there.
Just read @gvdhoorn's replies (and thank you for the reply): when I add uuv_control_msgs to the find_package(catkin REQUIRED COMPONENTS..) command, it spits out an error like the one I edited in, claiming that it already has those targets. This persists even when I remove the other packages.
@swordsgnat: Did you remove uuv_control_msgs from generate_messages() after adding it to find_package()? That last error is saying that there's already a package with the name uuv_control_messages . See https://github.com/ros/catkin/issues/477
Yes sir - and that error crops up even if I remove the whole generate_messages() line.
@swordsgnat: please update your original question with the contents of both package.xml and your edited CMakeLists.txt. Also: do an rm -rf /home/ncope/catkin_ws/build and rm -rf /home/ncope/catkin_ws/devel. Then try again.
Also: remove genmsg and message_generation from your find_package(catkin ..) statement, unless you are actually defining your own messages.
Reattempted after the rm lines, and I got a new error. I edited it in. I've never touched package.xml - is that the issue?
You should get a different error in that case (something like "uuv_control_msgs should be a build depend of X"), but in any case: check C++ message or service dependencies to make sure you have everything correct.
The error message you quote seems to suggest that Catkin (or really: CMake) cannot find the uuv_control_msgs. Make sure you don't have a typo in there somewhere.
I would also suggest to add some entries to your catkin_package(..) call, but that can be done later.
