Hi all, I'm trying to build my first URDF model, following this tutorial: http://wiki.ros.org/urdf/Tutorials/Building%20a%20Visual%20Robot%20Model%20with%20URDF%20from%20Scratch
Booth replicating what's done there, and cloning this repo too, I can't see any mash or shape in rviz, only transformations; here's what I see from chap.4 code:
image description http://imageshack.com/a/img924/7439/FGZxFt.jpg
There should be cylinders and squares...
Anyone experiencing this issue? I'm running ROS Lunar, Ubuntu 17.04 x64 on VirtualBox (with "3D acceleration" disabled because i don't know why, if it's enabled rviz trows segmentation faults at start)
Side note: chap.1 I think it's buggy because with no joints there's not any "base_link" transformation supplied by joint_state_publisher, and Rviz go crazy...
Originally posted by Maik993 on ROS Answers with karma: 1 on 2017-09-22
Comment by gvdhoorn on 2017-09-23:
We're probably going to have to see what the contents of your URDF is.
Comment by Maik993 on 2017-09-24:
I went further and complete the model, the result is an exact copy of this. In rviz I still don't see any shape, but launching the same file in Gazebo produce a correct visualisation of the entire robot.
Comment by gvdhoorn on 2017-11-20:
This could be caused by locale settings. See ros-visualization/rviz#1151.
