When I do
rosdep install camera_calibration
I get the following error:
ERROR: Rosdep cannot find all required resources to answer your query
Missing resource camera_calibration
ROS path [0]=/opt/ros/kinetic/share/ros
ROS path 1]=/home/tintin/catkin_ws/src
ROS path [2]=/opt/ros/kinetic/share
A similar question was posted here but there isn't a complete solution yet. I tried the solution given there too.
  1. For
sudo apt-get install camera_calibration
I am getting "Unable to locate package camera_calibration"
  1. For
sudo apt-get install ros-fuerte-image-pipeline
I am getting "Unable to locate package ros-fuerte-image-pipeline"
Originally posted by Sulphur on ROS Answers with karma: 3 on 2017-09-12
From the errors that you posted it looks like you're using Kinetic. I'm not sure about the error that you're getting with rosdep, but the reason that you can't install image_pipeline (which contains the camera_calibration package) is because you're trying to install the version for Fuerte. Try
sudo apt-get install ros-kinetic-image-pipeline
You can install many packages using the following command format
sudo apt-get install ros-<distribution>-<package-name>
where <distribution> is the distribution that you're using and <package-name> is the package that you're trying to install.
Originally posted by jayess with karma: 6155 on 2017-09-12
Comment by bansi_lol on 2020-06-26:
I tried the same command sudo apt-get install ros-kinetic-image-pipelline but with my distribution name which is ros melodic but it have the same error cannot find package what could be the problem then?
Sorry my mistake I copied and pasted the command and didnt notice there is a spelling mistake **pipeline
Comment by jayess on 2020-06-26:
Thanks for catching the mistake. I've updated the answer.
